Closed Thread
Results 1 to 2 of 2
    Aug 2012
    Problem with Babylon Hijacking Chrome
    Hi I am having problems removing babylon search redirects from my chrome browser ( as well as other browsers). On chrome, I have changed the settings and also removed babylon-associated files from the regedit, yet everytime i restart chrome, the default search settings are reset to babylon. I would appreciate some help on how to remove it, I have done some scans using Malware Antibytes and Hitman pro which have been unable to locate it.
    Thanks a bunch
    ph34r t3h g04t Whir's Avatar
    Kingsford, MI
    29,244
    7
    Help Remove Babylon Search - Malware?
  1. Chrome Re-Direction Problem.
    By vr67 in forum Technical Support
    Last Post: January 21st, 2012, 11:38 PM
  2. XP help/hijacking possible
    By LUKEDEICHER in forum Applications and Operating Systems
    Last Post: October 23rd, 2010, 11:14 PM
  3. A creative way to foil a hijacking
    By Toadman in forum IMO Community
    Last Post: February 19th, 2007, 07:09 PM
  4. Browser HiJacking!!!
    By JayMan in forum General Tech Discussion
    Last Post: November 20th, 2003, 12:23 AM
  5. Something is hijacking my favorites
    By Wombat in forum Applications and Operating Systems
    Last Post: July 25th, 2003, 12:10 PM
