X problem
Currently Active Users: 1542
Discussions: 200,952, Posts: 2,379,481, Members: 246,323
Old July 21st, 2002, 04:56 PM   Digg it!   #1 (permalink)
Send a message via AIM to Steelysteel
X problem
I've installed a new video card. Upgrade of a Geforce 2 mx to a Geforce 4 Mx. kudzo found the new card and asked me did I want to get rid of the old card configuration. I said yes.
I downloaded the source files for linux from Nvidia.com and did the normal make install.
Now, when i start X it says that it can't find the GLcore module and X will not start.
here are some excerpts from the XFree86.0.log file
"(II) LoadModule: "GLcore"
(WW) Warning, couldn't open module GLcore
(II) UnloadModule: "GLcore"
(EE) Failed to load module "GLcore" (module does not exist, 0)"
"NV(0): DPMS enabled
Symbol __glXActiveScreens from Module /usr/X11R6/lib/modules/extensions/libdri.a is unresolved!
Symbol __glXActiveScreens from module /usr/X11R6/lib/modules/extensions/libdri.a is unresolved!"
Looking through the readme file it states that the above section should read "II NVIDIA(0):....." not "II NV(0)...."
Anybody had this trouble?? How can I fix it without re-installing?
Steelysteel is offline   Reply With Quote
Old July 21st, 2002, 05:08 PM     #2 (permalink)
Germ's Avatar
Send a message via AIM to Germ Send a message via Yahoo to Germ
Under the Module section of /etc/X11/XF86Config-4, comment out Load GLcore and Load dri
it should look somethinmg like:
Section "Module"
# Load "GLcore"
Load "dbe"
# Load "dri"
Load "extmod"
Load "glx"
Load "pex5"
Load "record"
Load "xie"
Load "v4l"
EndSection
when you are through.
How do you set this laser printer to stun??
Germ is offline   Reply With Quote
Old July 21st, 2002, 05:08 PM     #3 (permalink)
Cody's Avatar
Did you follow the Readme on nVidia's site?
May sound but in Linux if you are told to read it, read it.
URL: http://download.nvidia.com/XFree86_4...960/README.txt
Cody
Cody is offline   Reply With Quote
Old July 21st, 2002, 05:11 PM     #4 (permalink)
Cody's Avatar
Also make sure you changed
Driver "nv"
to
Driver "nvidia"
Also also add
Load "glx"
to the Modules section
Cody
Old July 21st, 2002, 05:14 PM     #5 (permalink)
I am a banana!
originel's Avatar
Send a message via AIM to originel
try what was mentioned above. that *should* do it. if not run Xconfigurator and just create a new xf86config-4 file.
originel is offline   Reply With Quote
Old July 21st, 2002, 06:51 PM     #6 (permalink)
Ok. I have made the changes you all have suggested. I also ran Xconfigurator and created a new XFree86 file but my problem is with the installation of the kernel driver. I get error saying that file is not found.
"/usr/include/asm/timex/h:10:21 asm/msr.h: no such file or directory"
this is when I run the :make install command for the Kernel.
This is being done on RH7.3 btw. I downloaded the tar's from Nvidia's website.
Any additional Ideas???
Old July 21st, 2002, 09:22 PM     #7 (permalink)
bump
Please help!
Old July 21st, 2002, 11:07 PM     #8 (permalink)
gothic's Avatar
Make sure you have the kernel-source RPM installed...
gothic is offline   Reply With Quote
Old July 22nd, 2002, 12:36 AM     #9 (permalink)
I'm not using the RPM's. I'm installing from the source .gz file.
Is It Just Me? (2943)
Print spooler problem (15)
Laptop with wireless problem. (4)
Virus advise (8)
Internet Lost (3)
How to convert MP3's (4)
Asus P4G8X Mobo (6)
