July 22nd, 2002, 03:35 PM #1
Need Help Unlocking my Xp 1800+...
I noticed that there are several different ways to unlock them. If you have successfully unlocked your XP cpu, can u post your method please?
So according to what people have been saying, is this one way I can do it?:
-I rub the yellow crayon over the L1 pits, so it ends up looking kind of like this..
the "equal" signs is the crayon OVER the L1 pits. Is that correct so far?
-Then rub a pencil eraser over the dots just to make sure no crayon got on them right?
-Then take a conductive pen (or wutever YOU used), and connect the dots, so I will end up with 5 lines going down, OVER the crayon, right??
I just need to know what other materials u guys may have used other than a conductive pen, or paint, and your method. Thanks in advance...ThE GreatwhitE~
AMD 2600+ mobile
Abit NF7 v2.0 w/ d10beta4 bios by tictac
vdimm vdd & NB modded [thnx Hell Fire]
2x256mb TwinMOS pc3700 43B
Radeon 9800Pro @ 450/380 [mods in progress]
Thermalright SP-97 + Smart Fan II
WD 1200JB 120gb hdd
Lian Li PC-60USB
TTGI 520SS +5v +12v modded [thnx OPPAINTER]
19" ViewSonic A90
Lite-On 52x32x52x CD-RW
Windows XP Pro
my heatware
help support us on mIRC! :cool:
irc://irc.gamesurge.net/dynamic.cs
July 22nd, 2002, 03:36 PM #2
http://www17.tomshardware.com/column/01q4/011124/
video on how too
Paul to be honest I think its MS way of testing the water to see how the consumers will react
Xbox One Announced
