ram problem- help!  | |
July 23rd, 2002, 11:57 PM
I'm working on my brothers sys. We added a ge3 and boosted his ram to 256 from 128. Well then the probs started- BSOD's (blue screen), spontaneous reboot, illegal operation errors, fatal exception errors, lockups/crash in game (half life/cs), lost connection to the internet (cable connection) are the most common. So we took the extra ram out (back to 128) and all was fine again. So it's not the vid card or drivers. We used PNY single side, then PNY double side, last but not least samsung double side to no avail. Here's the sys specs:
Windows 98SE
Pentium III 600mhz
VisionTek GeForce 3 Ti200
Intel CC820 Mobo (2 banks for memory)
256mb ram PC100 SDRAM (currently)
AT&T cable ISP
Thanks ahead of time for any help. |
July 24th, 2002, 12:08 AM
Check the mobo specs on the manufacturer's webiste. You may need to upgrade the mobo BIOS in order for it to use PC133 RAM in an older mobo. Some don't support it at all. Check the mobo specs first.
The other issse may be timing, which may be able to be set in the BIOS, but maybe not per slot.
Sometimes you need matching RAM. Try two sticks of PC133 instead of 1 of PC100 and PC133 and see if that works, and try one stick of PC133 by itself to seee if that works.
Good luck
Cheers
Mick | |
| | Best To Avoid Me
Welcome to TechIMO!!! Intel® Memory Translator Hub (MTH) Reboot Issue
Do you think this might be your problem? Click this link and read on... http://www.intel.com/support/mth/
Mike
July 24th, 2002, 12:14 AM
| | | Quote: |
This issue does not impact boards or systems using the Intel® 820 chipset with RDRAM* memory, boards or systems shipped before November 1, 1999
| (from Martoch's link)
How old is the board??
Cheers
Mick | |
July 24th, 2002, 12:16 AM
| | Best To Avoid Me
Check Your System ecvtony!
Checking your system is not required if your board or system:
Uses the Intel® 820 chipset with RDRAM* memory
Was shipped before November 1, 1999
Is a mobile computer board or system of any kind
(laptops, notebooks, etc.)
Non-Intel 820 Chipset based boards |
July 24th, 2002, 12:26 AM
i believe the board is vintage 1999. we bought and used pc100 because that's what was in it. if i'm not mistaken there was a prob running pc133 at the time of it's manufacture hence the use of pc 100. it's a well built sys and runs fine till we add the ram back. i will check the bios settings. |
July 24th, 2002, 12:53 AM
Right off the bat, cut the CAS back to 3, if it's on 2.
If you can bump up the ram voltage a fraction of a volt (say 0.1v), try that. Might also try a smidgen more voltage to the processor.
Try the ram in each combination of slot/dimm possible.
Beware the Penguinator!
