just installed XP. how do I get the little hardware monitor out of system tray??
Currently Active Users: 1598
Discussions: 200,505, Posts: 2,374,392, Members: 245,829
Old August 4th, 2002, 02:27 AM   Digg it!   #1 (permalink)
Send a message via AIM to zskillz
that is pretty much the entire question... I can't remember how, and I can't think of a better place to find out!
thanks
-Z
zskillz is offline   Reply With Quote
Old August 4th, 2002, 03:13 PM     #2 (permalink)
now I happen to know that there are a lot of intelligent people here.. .no one knows??
-Z
Old August 4th, 2002, 03:15 PM     #3 (permalink)
Inanis's Avatar
I have installed XP dozens of times, and I've never had a hardware monitor in the system tray.
Are you sure it isnt a hardware monitor for your motherboard?
"A good technician, is always prepared."
Inanis is offline   Reply With Quote
Old August 4th, 2002, 03:46 PM     #4 (permalink)
Fossil
Theophylact's Avatar
Whatever it is, you can probably get rid of it by doing start>run>, running msconfig and unchecking it in the "startup" tab. Assuming it's not vital to the operation of the computer (highly unlikely), it should then be gone after rebooting.
Theophylact is offline   Reply With Quote
Old August 4th, 2002, 03:47 PM     #5 (permalink)
Fossil
By the way, what do you get if you open it?
Old August 4th, 2002, 05:04 PM     #6 (permalink)
I believe it is there because I have a zip disp that is usb (as well as multiple other usb devices) plugged in. when I scroll over it, it says "safely remove hardware"... it looks like a little green arrow floating overs a grey box-like thing...
that help at all??
-Z
p.s. - it's my dad's computer.. not mine
Old August 5th, 2002, 04:08 AM     #7 (permalink)
Otaru's Avatar
Laptop? If so that is normal. This is to protect some devices that require the removal part. On a Desktop PC it is uncommon.
SPECS:
Gateway M-675X
P4 3.0GHz 512k w/HT
512 Megs DDR
Radeon 9700
80Gb HD
Wireless B/G
Intel 10/100/1000 NIC
17.1" Widescreen
4x DVD+/-RW
Otaru is offline   Reply With Quote
Old August 5th, 2002, 04:13 AM     #8 (permalink)
Speed's Avatar
Location: Montclair, California That BURNING smell isnt my computer... IS IT????
Send a message via ICQ to Speed Send a message via AIM to Speed Send a message via Yahoo to Speed
Click on it and on the screen that opens up there should be a check box on the bottem that says " do not display icon...." or something to that effect.
That smells not my computer... IS IT????
Speed is offline   Reply With Quote
Old August 5th, 2002, 06:00 AM     #9 (permalink)
i thought so to otaru, but it's there and it's a desktop (lots of usb stuff plugged in though)
speed, I was hoping for that as well, but it's not an option!
any more suggestions?
-Z
Old August 5th, 2002, 06:05 AM     #10 (permalink)
Otaru's Avatar
Disabling the Icon is safe it is just there to turn off the device before removing it USB is hot swapable so no need to have the icon.
Is It Just Me? (1635)
Review My Build (5)
My 1st pc build (40)
Aero in Vista (7)
How to Ship a PC (16)
slaving laptop drive (7)
Review My Build (5)
2009 Build (4)
hard drive problem (2)
Hard Drive test program (2)
New Linksys Routers (2)
Mic won't work. (2)
