beep codes? CPU fried? Help Please.  | |
August 8th, 2002, 07:29 PM
| | OH NO!
I just picked up a chaintech 7AJA2 mobo. Installed my t-bird,HSF,128 mb ram ( 1 stick) and my AGP Nvidia vanta. I get 1 long beep, and 4 or 5shorts, can't count that fast. Does this mean the CPU is fried?
It has Award BIOS.
Thanx In advance.
August 8th, 2002, 07:33 PM
you could take out the vid card, try and see if the beeps are different
or if it beeps for ram, try taking it out, and seeing if its different
or take out the cpu and see if the beeps are different
dunno what, if any help that would be.. you could always find a manual
--Jacob--
August 8th, 2002, 07:41 PM
| | OH NO!
August 8th, 2002, 07:43 PM
Award BIOS Beep Codes:
Beeps ,Error Message ,Description
1long, 2 short = Video adapter error Either video adapter is bad or is not seated properly. Also, check to ensure the monitor cable is connected properly.
Repeating (endless loop) Memory error Check for improperly seated or missing memory.
1long, 3short = No video card or bad video RAM Reseat or replace the video card.
High frequency beeeps while running Overheated CPU Check the CPU fan for proper operation. Check the case for proper air flow.
Repeating High/Low CPU Either the CPU is not seated properly or the CPU is damaged. May also be due to excess heat. Check the CPU fan or BIOS settings for proper fan speed.
CBB |
August 8th, 2002, 08:03 PM
Jeez, you guys type fast, I was just lookin this up on my HDD when.............
Kewl, It works.
CBB |
August 8th, 2002, 08:19 PM
I dont think the PC would beep at all if the CPU was bad or not installed properly
Got root?
August 8th, 2002, 08:23 PM
| | OH NO!
It feels good to be back on this little machine.
I,ver been using my 233, and it was sloooowww!, But now I finally got my 750T-bird back running, man a month s a long time lol.....
Anyway, I got some tweaking to do, be back later, just and to say it works pretty good as it is.  |
August 9th, 2002, 03:48 PM
| Quote: |
| Actually it does beep when there is no CPU, or it is fried, or it isn't seated properly. That's one cool feature of the BIOS beep codes, if you know what the beeps tell you, then there is a very good chance you'll find what's wrong with the PC  |
August 9th, 2002, 04:09 PM
actually the easiest way to know if your CPU is fried, is by that luscious barbeque aroma that emanates from your case....
Give a man a fish and you feed him for a day. Teach a man to fish and you feed him for a lifetime.
