Hi,
I've been having some clipping/cropping problems in dialog boxes of various programs. The dialog box just sort of stops where text should continue, generally making it difficult to fill in information.
The programs this occurs in seems to be diverse with no common trait among each (that I can see) - it's happened in a calculator program, a newsgroup reader and a few P2P programs (among others).
I've tried updating my video drivers and/or finding fixes online but I have been unable to locate any information about problems of this sort. I'm also not sure how long this has been occurring but I think it started with the first drivers I used.
I'm running a Sapphire OEM Radeon 7500 in a Soltek SL-DRV5 motherboard. Athlon XP 1800+, 256MB of PC2100 DDR, I don't think there's any sort of conflict with my AGP slot or anything but I have no idea of what could be causing this problem. Any ideas of what could be causing it or how to fix it? Thanks in advance.
edit: this is in Windows XP Professional w/ Service Pack 1 (although the problem was occuring prior to SP1)
NB: The attached image shows the problem in action.
