computer won't power up
Currently Active Users: 2760
Discussions: 200,966, Posts: 2,379,646, Members: 246,332
Old December 30th, 2002, 01:27 PM   Digg it!   #1 (permalink)
Unhappy
Hi, I have a IN530 mother board w/amd 400 cpu the computer wont power up until several attempts of...spinning the 3 wire cpu fan while puhing the computer power on switch after which the computer runs perfectly. Where is my problem?Troubleshooting tips?
CPU
CPU FAN
POWER SUPPLY (THE SUPPLY SAYS ATE ON CASE)
MOTHER BOARD
OR ELSEWHERE
techless77 is offline   Reply With Quote
Old December 30th, 2002, 01:28 PM     #2 (permalink)
eclipsera's Avatar
Send a message via AIM to eclipsera
spinning the fan?! with your fingers? ive never heard of this...
but to answer your troubleshooting questions, how long has this been going on? did you change anything before it started happening? hardware wise or software wise for that matter
GA-7VAXP Ultra
WD 180GB 7200RPM
Razer Diamondback
SyncMaster 710T
GF FX 5900 Ultra
512MB RAM
Athlon XP 2000+ @ 1850Mhz
Corsair HydroCool 200 EX
eclipsera is offline   Reply With Quote
Old December 30th, 2002, 01:36 PM     #3 (permalink)
been goin for quite a while yes with my fingers or other small pointed object. computer was down for quite awhile with what turned out to be a bad cmos battery
Old December 30th, 2002, 01:39 PM     #4 (permalink)
eclipsera's Avatar
dont know if this would fix: tried clearin the CMOS? most boards haev a jumper you can move to clear the cmos. that MIGHT fix it, uh what wattage is the psu?
Old December 30th, 2002, 01:42 PM     #5 (permalink)
First thing to do would be to make sure that your getting enough power across the motherboard. Do this by taking out all of the add on cards, cd-roms, hard drives. I usually leave my video card in just so I can take a look at the cmos, but might be good to take that out also, if possible, and see if the board would then power on. If it does then start adding cards and devices back one at a time until you get back to where the system will not power on anymore. That should be your point where the system is trying to pull too much power.
You may also want to check the connections between the motherboard and the powersupply, and where the power-on button connects to the motherboard.
Kerros
Kerros is offline   Reply With Quote
Old December 30th, 2002, 01:43 PM     #6 (permalink)
eclipsera's Avatar
kerros i would have said also abut checking connections but he said when he spun the fan it started up.. i dont know.
Old December 30th, 2002, 01:45 PM     #7 (permalink)
cmos cleared same problem the dimensions of psu r 5" 4" 3 1/4"
(very small) alls it says is ATE W/NOISE KILLER on it no wattages
Old December 30th, 2002, 01:52 PM     #8 (permalink)
kerros like your idea will do that a little later if when I remove all current draws and the same result occurs what would u suspect?
thanks all!
Old December 30th, 2002, 01:52 PM     #9 (permalink)
Could be a protection on the CPU. It may be detecting an error with the CPU fan and powers down(or not boot) considering it works if you spin the fan... As for a solution, not sure, maybe new fan.
That's a possibility
Ram09
Ram09 is offline   Reply With Quote
Old December 30th, 2002, 02:58 PM     #10 (permalink)
Like Ram09's post it may be the CPU fan not spinning, which won't let the system start. try changing the power connections comming to the fan or switching that out if possible.
I had a problem with a Motherboard not powering on once, and it was a PCI slot that had a short... kindof... so it would sometimes not allow the system to turn on.
Is It Just Me? (3014)
Forty-six years ago today (9)
Internet Lost (5)
windows vista security holes (15)
Open With ..... Win7 (3)
Help getting around port 80 for camer.. (4)
Internet Lost (5)
virus blocking exe. files (1)
Nvidia GTX 260 problem (1)
Print spooler problem (16)
webcam (0)
upgrade for hp a6101 (0)
Virus advise (8)
