Right-click menu tweaks???
Currently Active Users: 1542
Discussions: 200,933, Posts: 2,379,171, Members: 246,297
Old January 9th, 2003, 10:02 PM   Digg it!   #1 (permalink)
Is it possible to change the order of the options in the right-click menu in Windows? I installed Winzip, but I'd like to put it's shell integration option BELOW the little horizontal divider if possible. I'd also like to be able to insert my own dividers to customize my right-click menu. There's tons of stuff I want to do, and any sites that have a lot of faqs and tutorials on how to customize the right-click menu would be excellent. I can find thousands of registry tweak sites, etc., etc., but not much on the right-click menu. Many of the right-click tweaks I've done were all registry hacks actually, but I can't find many places that focus on the shell.
PuddingShorts is offline   Reply With Quote
Old January 12th, 2003, 11:15 AM     #2 (permalink)
Supporting our military
Bill in SD, CA's Avatar
I don't know if this will help, but here goes:
Customizing Right Click Menu
Good luck and post back if you solve your query.
Bill
Bill in SD, CA is offline   Reply With Quote
Is It Just Me? (2877)
Obama the Muslim (14)
Ideal cheap graph card for PC-Gamin.. (17)
CPU fan stops spinning randomly (0)
Wireless Televisions. (0)
favorit (1)
Regular Build (3)
Fire in DVD (2)
Have you switched yet? (84)
Optical Audio A-B Switch (1)
