REdhat 8 and crystal 4236b sound
Currently Active Users: 2621
Discussions: 200,970, Posts: 2,379,723, Members: 246,335
Old January 20th, 2003, 12:04 AM   Digg it!   #1 (permalink)
scotlandtb's Avatar
Ok guys need a little help,
Redhat installed ok apart from sound which refuses to work,
Specs as follows
Dell GX1
P2 450
128MB
ATI 8mb onboard
Crystal CS4236b soundcard
10Gb HD
looking at hardware setup and under sound cards it has CS4236b:game
CS4236b:MPU
CS4236b:wss/SB
under unknown is
CS4236b:CTRL
when I try run volume control it says unable to open device
HEEEELP, am about to reformat and try Mandrake but before I do that thought I would see if any suggestions....if giving advice I need instructions as im a linux newb.....tried ALSA site but no joy.
scotlandtb is offline   Reply With Quote
Old January 20th, 2003, 12:33 AM     #2 (permalink)
scotlandtb's Avatar
Anything guys? reformat in 5 mins if no replys!!!!
Old January 20th, 2003, 12:42 AM     #3 (permalink)
Uncommon Man
samwichse's Avatar
Are you sure that's the right card?
I can't seem to find it listed on the manufacturer's website.
EDIT: You might try one of these drivers.
They're not for that exact number, but Cirrus Logic (the CS in that part number) doesn't seem to list that particular card.
samwichse is offline   Reply With Quote
Old January 22nd, 2003, 03:04 PM     #4 (permalink)
scotlandtb's Avatar
samwichse,
*LOL* been that busy not even looked at the problem since 20th. It is definatly a CS4236b, reading redhat site it should be supported by install CD, had look at anothe lRH8 system on same breed of PC and it has exact same prob!!!!!! been looking everywhere with no joy!!!!
BTW its a Crystal card not cirrus logic one (I know they are sorta same co)
Is It Just Me? (3040)
Delete an OS (14)
Forty-six years ago today (12)
Breaking: San Diego ACORN Document .. (7)
Nvidia GTX 260 problem (6)
Internet Lost (5)
Delete an OS (14)
Steam ID's, Gamertags etc... (3)
Open With ..... Win7 (3)
Internet Lost (5)
virus blocking exe. files (1)
Print spooler problem (16)
webcam (0)
upgrade for hp a6101 (0)
