XP Home SP1a install problem
Currently Active Users: 2412
Discussions: 201,011, Posts: 2,380,105, Members: 246,377
Old February 12th, 2003, 07:28 PM   Digg it!   #1 (permalink)
addicted
DVNT1's Avatar
Relatively new system running XP Home.
Trying to install XP SP1a this error constantly shows up stopping the install.
see http://dvnt1.homeip.net/help/netinstaller.JPG
Tried clearing temp files & rebooting.
Originally trying via Windows Update, last try was using the Network install version of SP1a.
Same erro rregardless.
Any suggestions?
DVNT1 is offline   Reply With Quote
Old February 13th, 2003, 01:00 AM     #2 (permalink)
kaziah's Avatar
I don't think it would a difference, but have you tried just the regular SP1? The only difference in the two, I think, is that Microsoft VM isn't included in SP1a... so I don't think that would make a difference... but hey, when you're stumped... sometimes anything is worth a try =) Including a hammer...
Have you tried the MS Knowledge Base?
kaziah is offline   Reply With Quote
Old February 13th, 2003, 07:59 AM     #3 (permalink)
addicted
DVNT1's Avatar
Thanks for your repley kaziah. I have not tried sp1 but I have learned there are other related problems with this machine.
Some other minor updates cause the same error message.
This machine can not add a modem based network connection (actually both modem and PPOE options are grayed out).
After a reboot, RPC services can not be started until the Telephone services are restarted.
I've searched Google and MSKB but no luck so far. The closest answer I've found is simply reinstall.
Old February 13th, 2003, 08:35 AM     #4 (permalink)
Banned
thronka's Avatar
Is this a custom built machine or is this a machine from Dell, Gateway..etc?
thronka is offline   Reply With Quote
Old February 13th, 2003, 08:39 AM     #5 (permalink)
Mean Moderator
EvilRick's Avatar
Can't see your image. Says " ... could not be found ..."
EvilRick is offline   Reply With Quote
Old February 13th, 2003, 08:55 AM     #6 (permalink)
I used an SP1 disc from a comp magazine,mainly 'cos my connection speed is so slow,so that method may help.I then "topped up" the SP via the web. As thronka asks what brand of machine are you using? Like ER I couldn't get to your link...
Best of luck to ya
Tagstar is offline   Reply With Quote
Old February 13th, 2003, 09:35 AM     #7 (permalink)
addicted
DVNT1's Avatar
link is also http://24.165.97.148/help/netinstaller.JPG
This is a "plain" Dell Dimension 4550 ( ~ $400 plain )
Old February 13th, 2003, 12:57 PM     #8 (permalink)
Xtreme Ultimate Member
Mntsnow's Avatar
Dvnt, Have you tried copying the SP from the network server to the local desktop and running it from there?
-Mntsnow-
Mntsnow is offline   Reply With Quote
Old February 13th, 2003, 01:19 PM     #9 (permalink)
DVNT1:
Since you're having probs with the other updates, etc., can you use the recovery disk to maybe overwrite, or otherwise fix those files/drivers which may be corrupted, and get your machine running like it should, before trying to install SP1 or SP1a?
Just an idea. . .
- Bill (who moved my cheese!?)
bill1971 is offline   Reply With Quote
Old February 13th, 2003, 02:04 PM     #10 (permalink)
addicted
DVNT1's Avatar
Mntsnow: yes, I copied the network install to the local computer and ran the sp1a install from that local copy
bill1971: I was installing SP1a in hopes to fix some previous software problems
At this point, it looks like a reinstall is what I will have to do. in approx. 6~8hrs
Is It Just Me? (3139)
‘Rogue’ or ‘Rouge’? (10)
Foxconn Blackops x48 MoBo (6)
Nvidia GTX 260 problem (14)
Delete an OS (18)
A good PSU? (11)
Best file format to play on Windows H.. (1)
Please Help. (2)
winrar decompresses, but video gone (0)
Advice for stopping IRQ BSOD is win7 (0)
cant access the internet (1)
COD radeon problems (0)
Unallocated Space (3)
Blackberry Bold 9000 (0)
Can't open Word (13)
Rar volume (number 7) (1)
System restore :) (1)
add ram to existing (4)
