java problems
Currently Active Users: 2722
Discussions: 201,002, Posts: 2,380,046, Members: 246,371
Old April 6th, 2003, 07:13 AM   Digg it!   #1 (permalink)
java problems
Hi
My computer is having trouble displaying java applets. The latest version of java is installed on my computer.
See the attached pic to see what happens. The java doesn't load and I'm left with an icon in the top left corner and a blank space.
I'm running WinXP PIII 650Mhz 256MB ram.
Ximensions is offline   Reply With Quote
Old April 6th, 2003, 07:38 AM     #2 (permalink)
When you say you have the latest version of java installed, are you talking the sdk, or virtual machine?
Turnip12 is offline   Reply With Quote
Old April 6th, 2003, 07:56 AM     #3 (permalink)
I'm not sure - what's the difference between the two? I went to java's website (www.java.com) and it said that I had java installed.
Old April 6th, 2003, 09:16 AM     #4 (permalink)
SPEEDO's Avatar
Send a message via ICQ to SPEEDO Send a message via AIM to SPEEDO
Try using the one offered here it's the one I have been using..........
Go Pats
SPEEDO is offline   Reply With Quote
Old April 6th, 2003, 01:10 PM     #5 (permalink)
Xi has the correct version. sdk is software development kit. it has the set of java development tools for compiling and running java applets and applications. tools are API classes, java Compiler and java virtual machine (JVM). compiler translates java source code into bytecodes which the JVM parse or runs to execute programs. JVM allows java codes to run on any machine (mac, pc etc) on which it is installed.
are you able to run your applet using appletviewer ? you seem to be using the windows browser. the tutorial link at sunjava site
should help.
http://java.sun.com/docs/books/tutor...efinition.html
isup is offline   Reply With Quote
Old April 6th, 2003, 02:43 PM     #6 (permalink)
I'm using Internet Explorer 6. I see the difference between sdk and vm, but that hasn't seemed to help my problem.
Old April 6th, 2003, 11:09 PM     #7 (permalink)
are your environment variables set ? can you run the applet using appletviewer command ? your html code could be the problem, eg. the WIDTH and HEIGHT dimensions may be too small to accommodate the applet. increase these and see what happens. good luck.
Old April 7th, 2003, 06:56 PM     #8 (permalink)
I'm not viewing an applet that I made myself, I'm trying to view java applets from other webpages online - such as yahoo games.
Old April 7th, 2003, 08:34 PM     #9 (permalink)
SPEEDO's Avatar
Go to Internet Options in the control panel and under Advanced see if the following is checked.
Old April 7th, 2003, 09:46 PM     #10 (permalink)
It was already checked.
Is It Just Me? (3126)
‘Rogue’ or ‘Rouge’? (10)
Foxconn Blackops x48 MoBo (5)
Nvidia GTX 260 problem (14)
Delete an OS (18)
Internet Lost (5)
Charge4All Black Friday Special (0)
Rar volume (number 7) (0)
System restore :) (1)
add ram to existing (4)
Delete an OS (18)
Print spooler problem (17)
Q9650 vs. Q9550 (2)
soundmon.exe (8)
Jedi Academy Problem (3)
