Hi there,
Hoping someone can help me, maybe even someone else has had this problem.
My system:
Athlon XP 1800+
512 MB DDR ram
K7VMM+ Mainboard
(WinFast A250 LE TD MyViVo Geforce 4 ti-4200 graphic card 128 MB)
Problem: Getting my Geforce 4 ti-4200 graphic card to work
The K7VMM+ mainboard comes with an onboard graphic card. Instead of this card I want to use my newly purchased Geforce 4 AGP card.
The card is AGP 4X/8X compliant and the mainboard supposedly supports AGP 4X - so the setup should work I believe.
I'm not a hardware expert, but I've installed plenty of hardware - I don't believe I'm making a 'beginners mistake' (such as the card not being plugged all the way into the AGP slot :-))
First I thought I was simplt supposed to plug in the new AGP card, and the mainboard would then automatically detect the card and use it instead of the onboard one.
This did not happen. I got no picture on my monitor, which as a result went into standby mode. This before my windows XP booted, so it has nothing to do with drivers etc. - I'm not even at that stage yet!
So - I thought probably I need to change some setting in bios. I did some reading up on the internet and it seems that yes, sometimes one does have to change a bios setting or alter a jumper setting on the mainboard to get it to use a card on the AGP slot instead of an onboard card.
However, I simply cannot find an appropriate bios setting (and I've searched quite thoroughly), and the 3 jumpers on the mainboard (from reading the documentation) have nothing to do with this. Only bios settings I can find are:
1) lets me switch between 1X / 2x / 4X AGP (AGP mode multiplied frequency)
2) AGP comp driving (apparently pertaining to currency - I have no idea what this is). It's default set to Auto but can be set to manual, and another setting can then be changed from CB to other two-letter settings (which I don't know what mean).
3) AGP aperture size. Default set to 64. Can be set to 8/16/32/64/128/etc..
4) Primary graphics adapter. Default set to PCI, can be changed to AGP. Documentation states that if the default PCI setting is set, the onboard card can still work and will allow a secondary display card to be installed on a PCI slot. I assume this should be set to AGP in my case (which doesnt change anything).
5) Allocate IRQ for PCI vga. Set to Yes. Kind of assuming this has no bearing on my situation.
But - no setting which simply states 'Use AGP slot instead of onboard graphic card', as I had hoped.
So.. I though maybe it was a bios problem and I just needed to flash a newer version. I did so, but all setting were the same..apparently no added features, and no change of my situation.
I'm hoping someone here can help me out, maybe even someone who knows the K7VMM+ mainboard a bit. (it's produced by ECS by the way).
Thanks in advance,
Tue Backhausen.
