comp problem
Currently Active Users: 2636
Discussions: 201,007, Posts: 2,380,081, Members: 246,373
Old April 6th, 2003, 03:48 PM   Digg it!   #1 (permalink)
comp problem
hey, I was changing my floppy drive and I had to unplug a lot of other stuff to make it fit... plugged it back in, though, and now my computer won't boot :\
makes a beeping sound when I turn it on, I had to take out the RAM and the IDE ribbon for a cd-rom and cd-rw to get it to fit... the floppy drive is also right above the hard drive so I hope I didn't mess that up heh :\
sorry if this is vague but I'm a newb, thanks in advance :P
somenewb is offline   Reply With Quote
Old April 6th, 2003, 03:54 PM     #2 (permalink)
the *Voice* in your Head
PresterJohn's Avatar
does the POST run or does it just beep?
if no post, remove and reseat the ram. check that all your cables (data & power) are properly connected as well.
Old April 6th, 2003, 03:54 PM     #3 (permalink)
oh yeah, motherboard is an IWILL P4R533, no usb connected, pc800 ram...
Old April 6th, 2003, 03:58 PM     #4 (permalink)
ok I read the definition for 'POST', I think that it's running... I'll make sure the cables and RAM are in properly now, thanks D:
Old April 6th, 2003, 04:03 PM     #5 (permalink)
Urban_Squrill's Avatar
Send a message via MSN to Urban_Squrill
Welcome to TechIMO!
Urban is back.
And yes that is how you spell my name. I am living proof that 2+2=5
dontforget/rgdesb
Urban_Squrill is offline   Reply With Quote
Old April 6th, 2003, 04:10 PM     #6 (permalink)
the ram seems to be ok but I'm not quite sure how to check if the cables are in correctly... if I removed the cables from everything but the hard drive, would it still beep or would I be able to see if that was my problem?
Old April 6th, 2003, 04:12 PM     #7 (permalink)
Banned
thronka's Avatar
did you make sure your have the correct cables in place? you might of put the ide cable in the floppy drive... i would unplug all the drives and BOOT up. Does it show anything?
thronka is offline   Reply With Quote
Old April 6th, 2003, 04:17 PM     #8 (permalink)
nurdonsite2's Avatar
yeah unplug all drives and boot up with just cpu, ram and video card.
EDIT: forgot to say, if it posts, then u probebly have cables plugged in the wrong places.
nurdonsite2 is offline   Reply With Quote
Old April 6th, 2003, 04:24 PM     #9 (permalink)
ok, I unplugged the IDE cables and the sound cables but I can't figure out how to get the power supply cables out, heh
thanks for all the help btw
Old April 6th, 2003, 04:41 PM     #10 (permalink)
jmebonner's Avatar
Power supply cables out of where, the drives? They just pull out.
jmebonner is offline   Reply With Quote
Is It Just Me? (3136)
‘Rogue’ or ‘Rouge’? (10)
Foxconn Blackops x48 MoBo (5)
Nvidia GTX 260 problem (14)
Delete an OS (18)
Need idiot-proof help for building a .. (0)
cant access the internet (1)
COD radeon problems (0)
Unallocated Space (3)
Blackberry Bold 9000 (0)
Can't open Word (13)
Rar volume (number 7) (1)
System restore :) (1)
add ram to existing (4)
Delete an OS (18)
