Weird problem!
Currently Active Users: 1860
Discussions: 200,923, Posts: 2,379,096, Members: 246,290
Old April 18th, 2003, 09:43 AM   Digg it!   #1 (permalink)
Send a message via ICQ to frodema Send a message via AIM to frodema
Question
Weird problem!
I'm having a weird problem with my box these days. Hopefully someome have a tip or something that can be usefull. What's happening is really weird, because I run the same apps and hardware as I have for the last 6 months, and it has never been any problems. If I sit by the box and use it active nothing ever happens. But every morning there's either a bluescreen telling some driver has messed up(mostly the video driver(nv4) or the firewall.sys). Sometimes it just runs on 100% though no services are running. The only suggestion I have is a newly replaced fan on my motherboard. This is the fan that cools the chip below the cpu, but all temperatures seems normal. Could the chip have been damaged before I got to replace the fan?? Would the board work if so??
Any comments, suggestions or thoughts are welcome.
frodema is offline   Reply With Quote
Old April 18th, 2003, 10:30 AM     #2 (permalink)
Unregistered
Lightbulb
Might Could Help....
AgentCrypto is offline   Reply With Quote
Old April 18th, 2003, 10:39 AM     #3 (permalink)
Of course...can't run any MS OS without anti-virus protection. Have tested the box with all kinds of anti-virus...my first thought too. But no virus found anywhere! This is my 3rd reinstall of windows...same happens everytime...clean install in the evening, messed up in the morning. And I don't really think the shop I bought the card from has anything to do with it...no offence.
Old April 18th, 2003, 10:46 AM     #4 (permalink)
Unregistered
Unhappy
Old April 18th, 2003, 10:52 AM     #5 (permalink)
smurffart's Avatar
Re: Weird problem!
Do you mean that the cpu is at 100% when you encounter this problem? Do you run any distributed computing projects? Have you run a check for spyware?
smurffart is offline   Reply With Quote
Old April 18th, 2003, 11:01 AM     #6 (permalink)
I run an FTP server 24/7, but has never had any problems like this. That usually doesn't use much of the resources. Why the cpu runs on 100% I can't figure out. When I have discovered this I have tried to close any running app/service, but after managing to close all apps it still runs at 100%. There is no spyware anywhere on my box I think. Check it with Ad-Aware every day.
Old April 18th, 2003, 11:09 AM     #7 (permalink)
the *Voice* in your Head
PresterJohn's Avatar
under task manager, what process is running at 100%??
Old April 18th, 2003, 11:11 AM     #8 (permalink)
None...that's the weird thing. But not all the time...only if the box has been running for several hours on it's own.
Old April 18th, 2003, 11:16 AM     #9 (permalink)
eh? during those times that you say the cpu is at 100%, how can there be nothing there?
don't count 'System Idle' of course...
Old April 18th, 2003, 11:25 AM     #10 (permalink)
Well...I can't tell really. As we speak I use the very same box, and everything runs perfect...server, firewall, chatclient, anti-virus, IE etc. But if I close everything but the server, and let the box run till the morning I either get the blue-screen with the driver failure, or the cpu runs on 100%. All regular services to run windows do of course run, but they don't use any resources...CPU usage at 0, but the total usage is at 100.
Is It Just Me? (2855)
Obama the Muslim (13)
Fire in DVD (0)
Virus Doctor Popup? (1)
SIS 740 and Widescreen (8)
