Compaq power supplies
Currently Active Users: 1568
Discussions: 200,506, Posts: 2,374,393, Members: 245,829
Old April 24th, 2003, 12:25 AM   Digg it!   #1 (permalink)
Cyberlore's Avatar
I have a compaq board, and that's about all the compaq left of my presario 5320US. I have a new 350 watt power supply. The **** thing isn't getting power from the new power supply. Yes it's plugged it. Yes, it's switched on, etc, etc. My fear is that compaq has their own wiring scheme for the atx connector. Anyone have any help as to where i can find this wiring scheme so that I can switch the pins around correctly?
And no, I'm a poor college kid who can't afford to buy a new board (unless there's a P4 w/ 400fsb board for ubercheap...sdram too...not ddr).
Cyberlore is offline   Reply With Quote
Old April 24th, 2003, 12:33 AM     #2 (permalink)
the *Voice* in your Head
PresterJohn's Avatar
i'm pretty sure that PS is standard...my question to you would be why you purchased a replacement PS. isn;t that thing still under warranty?
Old April 24th, 2003, 12:39 AM     #3 (permalink)
Cyberlore's Avatar
it's not a replacement...it's an upgrade from the 235 that came with it. and no, warrenty's out.
my gut tells me the **** thing's proprietary. comparing the wiring to the wiring specs of the new (and standard) supply, it's a little bit different...and on the compaq plug there is no pin 8 (strange). argh...darn computers.
Old April 24th, 2003, 12:44 AM     #4 (permalink)
mlee97's Avatar
Make sure you connect the p4 connector, most of those boards require it..
mlee97 is offline   Reply With Quote
Old April 24th, 2003, 12:46 AM     #5 (permalink)
not to split hairs (but since you brought up the definition of 'replacement')...but since you changed the PS, it *is* a replacement...albeit you are upgrading as well.
not able to find any documentation on the compaq site re:the mobo PS connects.
Old April 24th, 2003, 02:37 AM     #6 (permalink)
Cyberlore's Avatar
Yeah, P4 connector connected. Right now i've got my old ps sitting on a garbage can next to the case...looks pretty classy, i should take pictures. So I'm well aware how to plug it in...
And yes, you are correct, it is a replacement. To me, replacement seems to imply that the old one is broken or cant be used, whereas upgrade is to make it better than the current (and still usable) state. The english language just has too many different words
Old April 24th, 2003, 02:46 AM     #7 (permalink)
if the PS is incompatible...my sympathies
try calling compaq support or email them for more info. if they do indeed use a proprietary PS, you might want to consider a replacement mobo. p4 mobo's are fairly inexpensive...is your case a standard atx?
Old April 24th, 2003, 02:52 AM     #8 (permalink)
cyber,
also, try clearing the cmos and see if it boots up afterwards.
Old April 24th, 2003, 02:56 AM     #9 (permalink)
I'm silently judging you
ArcticFox's Avatar
Send a message via AIM to ArcticFox Send a message via MSN to ArcticFox Send a message via Yahoo to ArcticFox
You can almost rest assured that Compaq isn't like Dell, who rewires their PS's because it's "better" than the ATX standard. And if they did, your PC would be dead because of incorrect voltages going to the wrong places in your computer.
A couple things that could be preventing your PC from working are the P4 connector, a short, a dead power supply (try plugging in your old one; if it works... guess what!) Since you didn't take the mobo out I'm assuming, it's probably not anything to do with that.
Experiment, because it's only 200+ volts and however many amps, right?
ArcticFox is offline   Reply With Quote
Old April 24th, 2003, 03:05 AM     #10 (permalink)
Retired mostly.
Compaq doesn't use standard connectors.
My friends tried to insert a compaq mobo to a new case and nooo-o, the power cords just wouldn't fit on the mobo.
-M
Is It Just Me? (1635)
Review My Build (5)
My 1st pc build (40)
Aero in Vista (7)
How to Ship a PC (16)
slaving laptop drive (7)
Review My Build (5)
2009 Build (4)
hard drive problem (2)
Hard Drive test program (2)
New Linksys Routers (2)
Mic won't work. (2)
