PLEASE HELP, BAREBONE PC not working
Currently Active Users: 2643
Discussions: 201,007, Posts: 2,380,081, Members: 246,373
Old May 1st, 2003, 09:16 PM   Digg it!   #1 (permalink)
currently im on my old computer again because my new computer doesn't load and same thing again, it locks up but this time its at the setup screen like when u start up your computer and the system or maker name is displayed and u have to press a key to go into setup. well since i have a Geforce 4 Mx440se 64mb 4x agp, and i put it in tightly into the agp slot and start the pc it will load on the setup screen but only if it was off for along time. and then the screen/pc locks up. now they said i need to get a
pci card to upgrade bios/agp/ide and it should work when then i got a ATI Radeon 7000 32mb PCI and put that in and took out the agp card, it still locks up, i really need help now, i have everything straight, the amd 1.3ghz processor with 1.4 ghz fan (both socket A) and i put my old stuff in this pc like the hard drive and floppy and other upgrades i bought into that computer. and it won't go to the Windows 2000 screen boot. and it said something about floppy drive failure after i saved and exit, that was only 1 time i been on the pc that long on that pc. i don't get it. do i neeed to take the barebone PC back ????????
specs of new pc:
Soyo k7ada MD
256 DDR Ram Pc2100
Ati Radeon 7000 Pci 32mb
Geforce 4 Mx440se 64mb 4x Agp with tv out.
Philips 24*12*40 CD-rw
Athlon 64 3400+ (22-28*C)
ECS 755-A2 1.1B Bios
40GB & 80GB Internal HDD
160GB External HDD
Corsair 2GB PC3200 RAM
ATI AIW Radeon 9600 128MB 8X
soulja is offline   Reply With Quote
Old May 1st, 2003, 09:22 PM     #2 (permalink)
norml.org
thekingofpain's Avatar
Using the hard drive from the prior machine?
With all the OS/data etc on it?
thekingofpain is offline   Reply With Quote
Old May 1st, 2003, 09:26 PM     #3 (permalink)
yes, it has win 2000 and the size is 12.1 gb and the used space is 7.75gb
Old May 1st, 2003, 09:34 PM     #4 (permalink)
nurdonsite2's Avatar
so u mean that u never formatted the drive and reinstalled windows? if so, that might be ur prob.
nurdonsite2 is offline   Reply With Quote
Old May 1st, 2003, 09:38 PM     #5 (permalink)
prexaspes
Posts: n/a
Check the installation of your HSF on the processor. Ensure that it isn't installed backwards.
Old May 1st, 2003, 09:38 PM     #6 (permalink)
are you sure cause i think its a motherboard problem, thats what a tech from soyo said. but i have to be sure if it is. and y would it make my video card lock up and not show a screen at start up sumtimes.
Old May 1st, 2003, 09:42 PM     #7 (permalink)
backwards ? how can i tell
Old May 1st, 2003, 09:46 PM     #8 (permalink)
thats a pic of my motherboard and i hAVE THE fan wire coming out toward > so it can go to the plug pin at the top corner (Cpu fan. this pic is side ways so just look at it as it was upward in the right direction.
Old May 1st, 2003, 09:47 PM     #9 (permalink)
Kuasimodem's Avatar
Send a message via MSN to Kuasimodem Send a message via Yahoo to Kuasimodem
Like prexaspes says, if the heatsink is 180º out of alignment (backwards), then it won't make good contact with the processor die and the processor will overheat. This will cause the lockups.
Make sure that the step (indented part of the heatsink) on the bottom of the heatsink lines up with the step on the CPU socket (raised part next to the CPU when it's installed).
Kuasimodem is offline   Reply With Quote
Old May 1st, 2003, 10:00 PM     #10 (permalink)
it looks as its in the right place because the HS has a slight gap at the bottom, so u can have it on the part that has the name like the side with the 3 hooks but with the side that has Socket462 so its in right. anything else. and there is white compound on the fan, and now is on the cpu
Is It Just Me? (3136)
‘Rogue’ or ‘Rouge’? (10)
Foxconn Blackops x48 MoBo (5)
Nvidia GTX 260 problem (14)
Delete an OS (18)
Need idiot-proof help for building a .. (0)
cant access the internet (1)
COD radeon problems (0)
Unallocated Space (3)
Blackberry Bold 9000 (0)
Can't open Word (13)
Rar volume (number 7) (1)
System restore :) (1)
add ram to existing (4)
Delete an OS (18)
