Thread: HELP I need to clone HD
May 25th, 2003, 12:37 PM #1Junior Member
- May 2003
- Location
- Las Vegas
- 15
I have a 4 gig master hd that is almost full. I have a 30 gig slave drive. I would like to make my slave drive to be the master and install a new slave. how do I achive this.
May 25th, 2003, 12:53 PM #2
Unless I am mistaken this is easier than you may think...
determine the maker of your present Master drive, goto companies website and look under either downloads or support.
they should offer a utility to transfer files from one drive to another. Follow directions carefully, wich may include unzipping files to floppy and then rebooting with that floppy.
Its really not hard and once you start if you have any questions, myself and others will be more than happy to walk you through any steps.
this is a common thing most of us have had to do.
Ill keep checkin back to see how your doin!
Good Luck!!
May 25th, 2003, 01:03 PM #3
You should be able to go to the web site of the manufacturer of either the master or slave drive. They should have a cloning utility.
RayH42450@gmail.com
Please indicate you are from TechIMO in subject line so you don't get deleted as spam :)
May 30th, 2003, 03:49 AM #4Junior Member
- May 2003
- 12
Norton ghost does this kind of thing well. Ghost the Master to the slave and then hook up slave as master. All done....
Oh Ghost is a cloning software that you can buy at any retail store.
May 30th, 2003, 11:40 AM #5
I prefer Drive Image!
It tends to do a better job that Norton Ghost, and is a little easier to use.
Harder
at least you have some space between them so the primary card has some air flow to it. 75-80C is about average for temps on those, my 560 Ti's do about the same in a lot of games, some games run...
Temps too high? ( GTX 580s )
