well i have everything working fine but when i formatted my dvd-rw that came with the burner it would not let me delete any files that i had put on their
i used dla to do a drag and drop onto the dvd-rw but now i just cant delete anything off of it
windows XP would say
"CANNOT DELETE (FILENAME).AVI FILES ON THIS CD-ROM DRIVE ARE READ ONLY. YOU CANNOT COPY OR MOVE FILES OVER TO THIS CD-ROM DRIVE"
sony dru-500ax is compatible with all formats
i have a :
soyo kt400 dragon
2100+ amd
512 ram
tdk 48x cd-rw
sony 500ax
running windows XP Pro
i set the sony to master and the tdk to slave
both are running in a 2-1 ide cable to the motherboard
