POWER SUPPLY  | | |
June 1st, 2003, 10:34 PM
| POWER SUPPLY
HI, NEED HELP! TRYING TO POWER UP A CAR STEREO THAT
I PUT IN A BOX WITH SPEAKERS. NEED TO BE ABLE TO POWER
UP BY PULG IN ON THE WALL
WHAT DO I NEED?
WILL A 115V COMPUTER POWER SUPPLY WORK |
June 1st, 2003, 10:35 PM
Yeah, it should, I have seen it done before. |
June 1st, 2003, 10:44 PM
DOES THE POWER SUPPLY USE 12V AND GIVE ENUFF AMPS?
SEE IM NOT SURE HOW MANY AMPS A CAR STEREO NEEDS! |
June 1st, 2003, 10:53 PM
Just look on the power supply to see if the output of the power supply is in 12 volts. As far as the amperage, take the total peak output of the stereo and divide it by 12 volts and that will give you the amp rating necessary to run it..........I would guess about 15 amps or better should run most car stereos, since most have a max of around 45 watts per channel (180 watts / 12 volts = 15 amps).........
Shawn
Shawn
June 2nd, 2003, 12:13 AM
MAN, ALOT OF WIRES IN HERE COMING FROM POWER SUPPLY
WHERE DO I START? |
June 2nd, 2003, 12:31 AM
BONGMONGY, HOW ARE YOU DOING TO DAY? i JUST THUGHT I WOOD ASK U.
I HAVE VOICE EMODULATION DISORDER!!
MORAL: Please don't use all caps. It's like yelling at us.
Abit AW9D-Max | E6300 | XP-120 | Panaflow 120mm | 2x 1GB G.Skill DDR2-800 | BFG 8800GT | Tagan 480w
June 2nd, 2003, 12:34 AM
Ok, you need to hook up the 12v+ to the YELLOW wire on the PSU, it is your 12v+ and the Black wire next to it on the molex connector is the 12v-(Ground). |
June 2nd, 2003, 12:41 AM
| | Ultimate sumfin i guess
hahah i was wondering when someone would jump on the caps
June 2nd, 2003, 12:44 AM
Doesn't bother me one bit.. |
June 2nd, 2003, 12:48 AM
I think your gonna need a power inverter to go from the standard ATX connector to the stereo deck. They make them to go into car cigarette lighters and power a PC, but I'm not sure if they go in reverse...
Just my two cents
Talking in numbers doesn't make you smarter.
