CPU speed issue
Currently Active Users: 2006
Discussions: 200,936, Posts: 2,379,237, Members: 246,301
Old June 27th, 2003, 12:18 PM   Digg it!   #1 (permalink)
Question
CPU speed issue
First I just wanted to say that I just built my first computer myself and had fun doing it. No more wasting money on prebuilts, I thought it would be hard building a computer but its not. I was surprised at how easy it was, just follow the instructions! I replaced my mobo, CPU and RAM, bought a new case and kept some of my older computer parts, CD, video card, modem, NIC and put them in the new case. Now that I didn't have the problem with.
I used the old case and the old mobo, CPU and RAM to build my dad a computer, I added a CD, DVD, CDR, hard drive, modem, NIC for him. Now everything does start up and everything works fine, except I noticed that when I boot up it only says Athlon XP for the process but does not have the 1700+ after it and it also states that it is running at 1.1 GHZ. I thought the 1700's ran at 1.4GHZ. I checked my bios settings and the sdram is set to 133MHZ. Is there something else that I am missing? Not sure how I managed to get my new one okay with the CPU speed, but I'm not sure what I didn't do this time. Thanks for your help.
JimJRJ is offline   Reply With Quote
Old June 27th, 2003, 12:24 PM     #2 (permalink)
Telexen's Avatar
Are you sure the FSB is running at 100mhz though? there could be either a jumper, bios setting, or both to set this correctly...make sure it's set to 133mhz in your BIOS and check your manual for a FSB jumper
Telexen is offline   Reply With Quote
Old June 27th, 2003, 12:34 PM     #3 (permalink)
zidane182's Avatar
Send a message via ICQ to zidane182
your fsb is 100 mhz. 100*11= 1.1 ghz it should be 133*11 for ~1460 mhz
zidane182 is offline   Reply With Quote
Old June 27th, 2003, 12:38 PM     #4 (permalink)
Thanks guys, I will check it out when I get home from work and see where I'm missing something. Thanks.
Old June 28th, 2003, 12:30 PM     #5 (permalink)
It was the jumper on the mobo that was set to 100mhz. Everything is good now. Thanks everyone.
windows 7 problem (6)
Is It Just Me? (2899)
CPU fan stops spinning randomly (6)
Wireless Televisions. (8)
California Passes Anti-Flat-HDTV Le.. (41)
Obama the Muslim (14)
Have you switched yet? (85)
Regular Build (4)
Modern Warfare 2 freeze (13)
wireless user (1)
favorit (1)
Fire in DVD (2)
Optical Audio A-B Switch (1)
