Oh ! Need help with old HP Mobo!
Currently Active Users: 2606
Discussions: 201,004, Posts: 2,380,068, Members: 246,371
Old July 19th, 2003, 02:37 AM   Digg it!   #1 (permalink)
Hey all I decided to practice putting together a comp before my new comp parts arrived and so I took my 1998 Hewlett Packard Intel Inside Celeron Processor.
I took out all the parts and put them all back where they went but the Front Panel Cord that turns the power on/off.. I cant find where to put it! I looked all over every piece of the mobo and every other part and I couldnt find it anywhere!
The entire mobo is assembled but I dont know where to put the On/OFF Cord. I will put pics of everything when I find my damn digi cam but if anyone can help I would be very appreciative.
JeremyPC is offline   Reply With Quote
Old July 19th, 2003, 02:55 AM     #2 (permalink)
well, just one thing quick, better change the pottymouth in the title here.
THRUSH is offline   Reply With Quote
Old July 19th, 2003, 02:56 AM     #3 (permalink)
Smile
What potty mouth?
Tried to change but it only changes when you click on thread.
Old July 19th, 2003, 03:02 AM     #4 (permalink)
KenKun's Avatar
No profanity please.
The title was edited.
KenKun is offline   Reply With Quote
Old July 19th, 2003, 03:02 AM     #5 (permalink)
hmm, guess I never tried to change the title of a thread before. I'd just bite the bullet and notify a mod, who I'm sure can change it. I can definitely understand your frustration and the slip.
Anyway, so you lost the wire or the location where you are supposed to place the wires?
edit: wow! kenkun, that was fast, you guys can moderate my mind now too? when was this thought reading software put out?
Old July 19th, 2003, 03:05 AM     #6 (permalink)
Cant find where to put the case wire that turns everything on/off. I searched the entire dang thing. If anyone has ever used an older HP or made one please help.
Old July 19th, 2003, 03:13 AM     #7 (permalink)
do you have reset, hdd indicator light or any of that hooked up? I haven't looked at an old hp, but on the mobos I have worked with there is a cluster of these connections.
have you tried checking it out on hp.com's support site?
There are diagrams of the mobos and details on the connections, such as this one:
http://h20015.www2.hp.com/en/documen...604090#P33_628
shows diagram of mobo and scroll down 2/3 of the page to see diagram of front panel connections. Once you see the cluster on the board though, you'll probably see the connections labeled.
Old July 19th, 2003, 05:05 PM     #8 (permalink)
Ok the comp is an HP Pavilion 6545C, I am still looking all over the mobo for the plug, I have searched the thing everywhere. Where does the power to the front panel usually go?? I really need some help here. THnx
Old July 19th, 2003, 05:17 PM     #9 (permalink)
billniceguy's Avatar
Thumbs up
hpmobo
usually around8-10 pairs of pins in a row...speaker should be in the group...then just keep trying different pairs, or look on mobo with magnifing glass for clue like sw, pwr, etc.
billniceguy is offline   Reply With Quote
Old July 19th, 2003, 09:12 PM     #10 (permalink)
did you check on the board for a cluster like the one shown on the board at the link posted?
Anyway, I believe this is your board then:
http://www.hp.com/cposupport/persona.../bph05160.html
Look in the pic at the bottom of the page and it shows the front panel connections close to the lower left hand corner of the image. If you take a look on the board itself these connections should have some tiny labels around them.
Is It Just Me? (3132)
‘Rogue’ or ‘Rouge’? (10)
Foxconn Blackops x48 MoBo (5)
Nvidia GTX 260 problem (14)
Delete an OS (18)
Internet Lost (5)
cant access the internet (0)
Charge4All Black Friday Special - Twi.. (0)
Unallocated Space (3)
Blackberry Bold 9000 (0)
Can't open Word (13)
Rar volume (number 7) (1)
System restore :) (1)
add ram to existing (4)
Delete an OS (18)
