Need suggestions on parts
Currently Active Users: 1479
Discussions: 200,931, Posts: 2,379,161, Members: 246,297
Old August 9th, 2003, 04:04 PM   Digg it!   #1 (permalink)
hi, my 2000+ just went kaput. and i am thinkin of buildin a new one. i need suggestions on a mobo. this is what i have so far.
AMD ATHLON XP 2500+ "Barton" 333 FSB PROCESSOR 90$
need mobo
120 gb wd
512 kingston ddr
256 kingston ddr
geforce 4 ti 4200
audigy 2
really need help on mobo this is going to be for gaming
Dsword is offline   Reply With Quote
Old August 9th, 2003, 04:20 PM     #2 (permalink)
Send a message via AIM to Arcuivie
Mobo - Asus A7N8X Deluxe
If you are using only 2 sticks of RAM I wouldn't get 2 different sizes, why? I don't really know, lol. But 512 should be plenty, so get 2 sticks of 256.
Procrastination is the universes way of telling us to slow down, your moving too fast. Don't wait, procrastinate now.
Arcuivie is offline   Reply With Quote
Old August 9th, 2003, 04:27 PM     #3 (permalink)
Tazman's Avatar
This board has been getting Maximum PC's Kick Ass Award the last few months. Highlights are RAID, Dual LAN, nForce 2 chipset, 2 Firewire ports, 6 USB 2.0 ports, 6. sound. Sells for $124 shipping included
at NewEgg.
The last Asus board I used was the A7V333 which had alot of goodies but didn't overclock as easy as the Soyo Dragon.
Mike
Tazman is offline   Reply With Quote
Old August 9th, 2003, 05:35 PM     #4 (permalink)
alright thanks ill check it out...
and the reason i have two diff sizes is because i still have them from my old computer
Old August 9th, 2003, 05:46 PM     #5 (permalink)
cruiserlck's Avatar
I agree with both Arcuivie and Tazman , I'm running the deluxe version of that board and it rocks. I'm using the same cpu and video card on this board with 512md ddr pc3200 and it does very well.
cruiserlck is offline   Reply With Quote
Old August 9th, 2003, 05:57 PM     #6 (permalink)
Urban_Squrill's Avatar
Send a message via MSN to Urban_Squrill
Asus A7N8X Deluxe for sure! Thats what I am running and its great.
Urban is back.
And yes that is how you spell my name. I am living proof that 2+2=5
dontforget/rgdesb
Urban_Squrill is offline   Reply With Quote
Old August 9th, 2003, 06:19 PM     #7 (permalink)
Telexen's Avatar
I do believe the board will have problems if you run two sticks of differently sized RAM in dual channel.
Telexen is offline   Reply With Quote
Old August 9th, 2003, 06:25 PM     #8 (permalink)
sulusulu's Avatar
You might comsider the Giga-Byte GA-7NNXP . It has dual lan with gigabit, audio, dual BIOS, paralell IDE RAID, SATA, and four DIMM slots. But, it has a hefty prive at about $175 or so.
I've been htinking about getting on myself. Here is a Tom's Hardware review. The only issue that I know of is that it has no hole around the CPU for some big heat sinks.
sulusulu is offline   Reply With Quote
Is It Just Me? (2874)
Obama the Muslim (14)
Wireless Televisions. (0)
favorit (1)
Regular Build (3)
Fire in DVD (2)
Have you switched yet? (84)
Optical Audio A-B Switch (1)
