September 11th, 2003, 05:03 PM #1Junior Member
- Aug 2003
- 12
help plz my pc not working proply
right i am not going to bore you but i need help it doing my head in now
ok right my pc
K7N2G Mainboard
AMD Athlon(tm) XP 2400+ it's new
Memory 512 MB ddr
Geforce FX 5600
PUS- 400ws
ok install my new AMD CPU and i had more ram
and it all when wrong
the pc started ok and windows is ok but when i play 3d game i can play for 20min and it will freeze for close to desktop at first i fort it was the new CPU was other heating but i buyed and new fan for it and it about 45oc to 50oc that not to bad so then i fort it was the ram so i pulled that out and the game still freeze or close to desktop i did tests to ckeck the ram and that was ok then i did a test with the CPU and that ok so i restalled window last night and it still happens so i am lost what it could be now.
sorry if my spelling a bit edited
plz can some one help me it's doing my head in now
Welcome to TechIMO
Please refrain from using profanity here!
KenKun/Moderator
September 11th, 2003, 05:06 PM #2Junior Member
- Aug 2003
- 12
o and i am useing xp pro
September 11th, 2003, 05:06 PM #3
Please no cursing.
Sounds like you've got an overheating video card, rather than CPU or bad RAM. Possibly your case doesn't have enough ventilation to allow the video card to properly cool itself.
Unless the game is Morrowind, in which case crashing to the desktop is completely normal.
September 11th, 2003, 05:25 PM #4Junior Member
- Aug 2003
- 12
mm i don't now my case is a old mini atx case
i have 1 fan sucking and a fan extractor right by the card so do you thick that what up with it
September 11th, 2003, 05:33 PM #5Junior Member
- Aug 2003
- 12
when you look at the case at the front my case is 3 biro pens high and 1 and a bit long sorry have not rooler
do this help any one lol
None however can match the size of the explosion they say they saw March 17. NASA says the meteoroid was about 40 kilograms and less than a meter wide, and it hit the moon's surface at 56,000 mph. It...
