HELP! Lock ups and weird memory errors
Currently Active Users: 1880
Discussions: 200,978, Posts: 2,379,821, Members: 246,341
Old December 29th, 2001, 08:43 AM   Digg it!   #1
swamp-fox's Avatar
Unhappy
Last week I had to reinstall OS getting weird crashes.Thought i had a bug try to run norton virus scan aftr updating all virus files. Now it scans couple thousand files and locks up with blue screen I have run it many times and seems to lock up at same spot everytime. Also Norton works tells me both of my ram sticks are bad now. Try to run system restore from every restore point I have and it also stops about 40% through the job everytime??I put another stick of ram in it and went to check bios again and the ram timing was at cas2 instead of cas3 I know it faster at 2 just wondering how it changed itself? set at SPD I slowed the cpu down to 1000mhz Under standard in bios still not helping. I can't figure this out. Kids use my puter to go online alot thought maybe I have bug?? ERROR-file name Vcache(01)+000015A4 error:OE 0028:C004EC40and when I reboot I get (Unable to initialize the virus scanning engine database files). here are my specs.
asus a7v133 mobo
athlon@1.33ghz
geforce2 mx 400
512mb ram
win ME
swamp-fox is offline   Reply With Quote
Old December 29th, 2001, 08:52 AM     #2
AzKidd69's Avatar
Send a message via MSN to AzKidd69 Send a message via Yahoo to AzKidd69
Take a look at this....
And as far as norton telling you your ram is bad. I would not believe it. It has told me that many times when I know mine is good. I would try finding another utility to test the Ram...
AzKidd69 is offline   Reply With Quote
Old December 29th, 2001, 09:23 AM     #3
swamp-fox's Avatar
update
ok got norton to run all the way through with no viruses detected .Also coudn't run sysedit (from the mskb article you sent me) no file found with that name.Some people have told me norton system works is trash don't use it just use windows utilities Is there another ram tester I can't believe both sticks went bad one is kingston and one stick is from TCWO warehouse no name on it. When I was moving ram around, sytem woudn't boot with the no nome stick in by itself but would boot with kingston but norton said bad memory
Old December 29th, 2001, 09:44 AM     #4
I have seen problems with norton on the compressed files in windows. Try changeing the attributes to not scan compressed files.
I have seen this on Norton 2000/2001 models. 2002 seems to have cured this problem.
I wouldn't worry about the ram check. I don't know anyone who has had memory pass the norton test yet.
If it won't boot off the no name stick. It might be bad. Leave the Kingston in and get a replacement for the no name.
Philip1952 is offline   Reply With Quote
Old December 29th, 2001, 10:35 AM     #5
swamp-fox's Avatar
ok Uninstalled norton completely, running on one stick of kingston 128mb. For some reason I can't run the restore option to restore to a former date when system was working fine? It still hangs at about 40% and then reboots and my active desktop is gone. Earlier when I checked the restore option was disabled and I don't think I did that. This thing's been humming along for couple months with no problems untill few day's ago Thanks for advice I'll be checking back frequently as I'm trying different things and ay just reinstall win ME again. Would norton stop my system restore from backing itself up??? thinking out loud.Thanks
Old December 29th, 2001, 12:57 PM     #6
Norton won't stop the system restore. I just removed ME a couple of weeks ago. Norton had no effect on the restore feature.
Or at least 2002 didn't. I only used ME for about 1 month so I have not had it on Norton 2000 or 2001.
The way I did the resore part was. I turned it off the first thing on install. After I had windows and all my programs installed and working good. (I allowed 1 week for this part). Then I turned on system restore. I ran it for a couple of days then I turned it back off. That way it won't keep adding to itself and corrupt the back up. What you might have going on is a slow corruption of the regestry over time from system restore running. It adds each start up into the file and deletes an older one.
One small error on top of another it all adds up over time to a regestry that is bad. My version of ME didn't have system file checker on it. Or M$ removed it for ME ,one of the two. I like system file checker.
Old December 29th, 2001, 01:09 PM     #7
jerrygarcia's Avatar
Send a message via AIM to jerrygarcia Send a message via Yahoo to jerrygarcia
I had that sort of problem. I checked my ram in another computer and it did the same thing. Went out and bought 256mb Crucial and now running like a dream, well after I added that one, I went out and bought another 256.
jerrygarcia is offline   Reply With Quote
Old December 29th, 2001, 06:23 PM     #8
There you go try to over dose Windows.
Old December 30th, 2001, 06:03 AM     #9
Sounds like a RAM problem to me...
Try replacing with known good RAM & see what happens.
BTW- System Restore will generally not work if you are running a firewall program. Don't know if this applies in your case- just an idea...
Good luck
Lost1 is offline   Reply With Quote
Old January 2nd, 2002, 05:00 PM     #10
swamp-fox's Avatar
Update again
Thanks everyone seems to have been ram. had same problem while back are they making it defective now since its so cheap?? First two sticks I had to take back Now another gone bad all no name from TCWO. will stick with kingston or crucial
Thanks again
swampy.
Health Care Rationing (9)
Charges against non-tippers dropped.. (14)
Is It Just Me? (3062)
Delete an OS (16)
Nvidia GTX 260 problem (9)
windows vista security holes (18)
Point and Shoot Camera Suggestions. (7)
Internet Lost (5)
cheap gaming laptop? (11)
C# + LINQ Help (7)
[F@H SPAM 11/16/09] ! 1/2 months to r.. (38)
Dynex DX E-402 (3)
Delete an OS (16)
cell phone won't work (0)
Can't open Word (12)
Open With ..... Win7 (3)
Internet Lost (5)
virus blocking exe. files (1)
