HELP!!!!10gig harddrive only formatting into 2 gig parts
Currently Active Users: 2607
Discussions: 201,008, Posts: 2,380,089, Members: 246,374
Old October 1st, 2003, 12:07 PM   Digg it!   #1 (permalink)
stant093's Avatar
Send a message via Yahoo to stant093
why would this be happening?
i have a 10 gig harddrive here that has worked beautifully for ever, now that i have a deal going to trade it off, it will not format a 9gig partition like it allways has, only 2.4 gig partitions....wtf?
anyone have this happen to them?
I'd rather be driving a titelist
stant093 is offline   Reply With Quote
Old October 1st, 2003, 12:12 PM     #2 (permalink)
Mean Moderator
EvilRick's Avatar
What are you using to format?
Have you used 'FDISK' to see what partitions it shows?
Have you used the mfr's. utility to "verify" the drive?
EvilRick is offline   Reply With Quote
Old October 1st, 2003, 12:13 PM     #3 (permalink)
PCLinuxOS 2009.1
dunbar's Avatar
Send a message via ICQ to dunbar
Macintosh or Windows?
dunbar is offline   Reply With Quote
Old October 1st, 2003, 12:14 PM     #4 (permalink)
stant093's Avatar
its worked fine untill i wiped it clean, now using partition magic, i cant get it to make a solid 10gig +/- harddrive, only 2. something...
ill try the manuf utilities
edit win2k pro fat32 file system
Old October 1st, 2003, 12:18 PM     #5 (permalink)
Mean Moderator
EvilRick's Avatar
Are you making a FAT partition or FAT32.
Use 'FDISK' and enable "Large Disk Support" so you can make a FAT32 partition.
Also, did you move any jumpers? Check to make sure the 2GB clip isn't on.
Old October 1st, 2003, 12:26 PM     #6 (permalink)
stant093's Avatar
arg, the easiest yet last thoguht of solution..thank you evilrick, i owe ya one...lets let this thread die so i dont look too much like a moron
Old October 1st, 2003, 12:33 PM     #7 (permalink)
Mean Moderator
EvilRick's Avatar
Happens to the best of us.
Although I've never done it.
Is It Just Me? (3136)
‘Rogue’ or ‘Rouge’? (10)
Foxconn Blackops x48 MoBo (5)
Nvidia GTX 260 problem (14)
Delete an OS (18)
cant access the internet (1)
COD radeon problems (0)
Unallocated Space (3)
Blackberry Bold 9000 (0)
Can't open Word (13)
Rar volume (number 7) (1)
System restore :) (1)
add ram to existing (4)
Delete an OS (18)
