overheating problem  | |
October 1st, 2003, 09:22 PM
| overheating problem
The problem started when I turned the computer on. I when out and came back and the screen was black and nothing worked.
I turned it off and then on and this time it took a lot to start. It was to slow. I checked inside the computer and the video card, the RAM and the HD were all overheated. Its that normal becasue I dont think that hapened before. Right now the computer is working fine but it's still a little slow. And it only takes some minutes for the things to get overheated. |
October 1st, 2003, 09:27 PM
| | Best To Avoid Me
Welcome to TechIMO!!!
Would you mind posting up your system specs? Also, go into your bios and see just how hot your system is getting...post up a little more info and we'll do the best we can.
October 1st, 2003, 09:58 PM
this is what I got
Intel Pentium 4 CPU 1400MHz
128 MB of RAM
18 GB HD
32 MB NVIDIA RIVA TNT2 Model 64
Windows xp
Where can I check how got its getting.
And thanks for helping |
October 1st, 2003, 11:24 PM
"To announce that there must be no criticism of the president, or that we are to stand by the president right or wrong, is not only unpatriotic and servile, but is morally treasonable to the American public." ---Theodore Roosevelt
October 2nd, 2003, 12:15 AM
here is the temps
HD-118*F
CPU-100*F
Board 98*F
I couldn't get the temp for the video card
thanks for the link pickel |
October 2nd, 2003, 12:35 AM
Temps seem ok , I would think. If you're worried, add another fan to draw more air thru the box. If your power suplly just draws fron the back,, cut out the bottom and install a screen so it draws air over the cpu. I did that on my last build. |
October 2nd, 2003, 12:41 AM
This may sound really trivial, but have you tried running the computer without the cover and check temps.
This will allow you to determine whether its an insolation problem or hardware is just running in high temps, but as pickel state the temps seem fine.
just throwing ideas around
good luck |
October 2nd, 2003, 04:38 PM
thanks guys for every thing. Today everything is working fine, and I guess the heating is normal. |
