fried mobo/need upgrading help
Currently Active Users: 2691
Discussions: 201,002, Posts: 2,380,048, Members: 246,371
Old October 1st, 2003, 10:16 PM   Digg it!   #1 (permalink)
First off I fried my mobo. Now Im about to upgrade to a Nforce2 mobo but I know that I wont be able to boot my hard drive in my new mobo. How do I go about upgrading my mobo then?
OS: Windows XP pro
HDD: WD 60gb 2mb cache
pinoy87 is offline   Reply With Quote
Old October 1st, 2003, 10:35 PM     #2 (permalink)
TOAD6147's Avatar
Send a message via ICQ to TOAD6147
There's many threads dealing with this issue and there are many approaches to the problem. Do a search and read several or all and try what's suggested.
foolish their lack of understanding."
Ambrose Bierce
TOAD6147 is offline   Reply With Quote
Old October 1st, 2003, 10:51 PM     #3 (permalink)
ph34r t3h g04t
Whir's Avatar
Why wouldn't you be able to boot with the new motherboard? The XP stuff? It shouldn't hassle you too badly.
Old October 1st, 2003, 10:55 PM     #4 (permalink)
See the thing is whenever I transfer my hard drive to another computer with a different mobo it says OS not found. But then I tried it on my brothers old computer with the same exact kind of mobo I just fried and it boots. It seems like I cant use other mobo's with my hard drive.
Also when I set my hard drive as slave and another hard drive that is not windows xp and is fat32 the system doesnt recognize my hard drive.(This was before I fried my mobo so the drive was for sure working properly)
My hard drive is NTFS format.
Old October 1st, 2003, 11:06 PM     #5 (permalink)
pickel's Avatar
Send a message via Skype™ to pickel
Thumbs up
Just boot from the CD with the XP disc installed and re-install XP saving your settings.
"To announce that there must be no criticism of the president, or that we are to stand by the president right or wrong, is not only unpatriotic and servile, but is morally treasonable to the American public." ---Theodore Roosevelt
pickel is online now   Reply With Quote
Old October 1st, 2003, 11:27 PM     #6 (permalink)
ragtop's Avatar
If you boot an older OS (ie:WIN98) that doesn't support NTFS, then it won't recognize the NTFS drive. (but it should still be detected in BIOS)
Also: make sure the drive is properly jumpered for the configuration you are using. Some brands can be a little picky - ie: a WD drive set as master won't work if there's no slave drive installed on the channel.
ragtop is offline   Reply With Quote
Old October 2nd, 2003, 01:18 AM     #7 (permalink)
Pickel,
Thanks for the suggestion. Ill try that tomorow since thats when the parts are coming.
ragtop,
It is still recognized in the bios. The only thing is that after like 2 min of not booting up, it says OS not detected.
Are you saying my drive will be recognized if I made a drive thats NTFS with windows xp as master and mine as slave?
Thanks for the help
Ill check back tomorow if I have further problems.
Is It Just Me? (3126)
‘Rogue’ or ‘Rouge’? (10)
Foxconn Blackops x48 MoBo (5)
Nvidia GTX 260 problem (14)
Delete an OS (18)
Internet Lost (5)
Rar volume (number 7) (1)
System restore :) (1)
add ram to existing (4)
Delete an OS (18)
Print spooler problem (17)
Q9650 vs. Q9550 (2)
soundmon.exe (8)
Jedi Academy Problem (3)
