need small amount of help, at least i think this is an easy one
Currently Active Users: 2310
Discussions: 200,942, Posts: 2,379,291, Members: 246,305
Old October 4th, 2003, 04:24 PM   Digg it!   #1 (permalink)
have bios set for boot from cdrom, os is installed though, so do i change it to boot from c:/ now? also how do i make it so windows comes up and not all the system info at poweron?
sao95 is offline   Reply With Quote
Old October 4th, 2003, 04:26 PM     #2 (permalink)
stant093's Avatar
Send a message via Yahoo to stant093
yes, just change your boot order, i believe it standard for all the info to come on, that is the period it is reading from the bios
I'd rather be driving a titelist
stant093 is offline   Reply With Quote
Old October 4th, 2003, 04:33 PM     #3 (permalink)
Mean Moderator
EvilRick's Avatar
You might look for something like "Quiet Boot", this might show a splash screen of the PC mfr. or you mobo mfr. instead fo the POST process.
EvilRick is offline   Reply With Quote
Is It Just Me? (2918)
Wireless Televisions. (10)
Regular Build (6)
Asus P4G8X Mobo (5)
sms storage to PC (0)
Regular Build (6)
Open With ..... Win7 (0)
java code for fibonacci (1)
Have you switched yet? (85)
Modern Warfare 2 freeze (13)
wireless user (1)
favorit (1)
Fire in DVD (2)
