Join TechIMO for Free!
Thread Tools
Currently Active Users: 2698
Discussions: 186,606, Posts: 2,227,046, Members: 230,240
Old December 31st, 2001, 03:09 PM   Digg it!   #1 (permalink)
ben-the-slacker's Avatar
What the...?!?! Sound gone!!
Ok...I disassembled my computer to have a peak inside and to clean it out. By disassembling, I mean totally disassembling. Every piece of hardware taken off the mobo, mobo taken off the tray, everything cleaned out. But then when I put the system together and turn on, the computer beeps at me. So I turn it off and check the wiring and turn back on. Still beeps. So I turn off...well, to say the least, I had to do this about 3 times before the thing would boot.
With that done, I proceeded to listen to some music on Winamp. Well, when I tried to play, the thing would give me an error message: "MMSYSTEM002A device ID has been used that is out of range for your system." WTF?! My sound's gone?! So I went into Device Manager and saw that a sound peripheral wasn't even listed. What's going on here with this computer?
Can someone please help me?
ben-the-slacker is offline   Reply With Quote
FREE instant scan
Old December 31st, 2001, 03:12 PM     #2 (permalink)
Kawaru wa yo!
Whir's Avatar
Onboard sound? If not, did you switch which slot the Soundcard was in??
-Whir
Old December 31st, 2001, 03:13 PM     #3 (permalink)
It's an old ESS isa sound card. I put it back in the same slot that I took it out of.
Old December 31st, 2001, 07:23 PM     #4 (permalink)
SPEEDO's Avatar
Send a message via ICQ to SPEEDO Send a message via AIM to SPEEDO
Are you sure you shoved the card all the way into the slot?
SPEEDO
Go Pats
SPEEDO is offline   Reply With Quote
Old December 31st, 2001, 07:26 PM     #5 (permalink)
Fur ballin
Sixpac_XP's Avatar
Could you please list the specs and o/s of your system so we can figure it out a bit better...
Thanks.
sixpac
--- Standby to receive our transmission ---
Sixpac_XP is offline   Reply With Quote
Old December 31st, 2001, 08:00 PM     #6 (permalink)
chefde's Avatar
Go into control panel/system & remove sound card then re-install
Chef
chefde is offline   Reply With Quote
Old December 31st, 2001, 08:19 PM     #7 (permalink)
SPEEDO: I shoved the card in as far as it would go.
Sixpac:
My system specs are...
188mhz Cyrix Socket 7
Epox EP-BVPXB AT mobo
3.1 Seagate hdd
1mb Trident vid card
ESS ES1869 sound card
32mb pc66 SDRAM
Chef: the system doesn't detect a sound card although I've got it in the slot, so I can't uninstall it. I tried to go Control Panel->Add new hardware, but after installing the sound still didn't work.
Please help!!
Old December 31st, 2001, 08:30 PM     #8 (permalink)
cadetstimp's Avatar
Is the Video Card firmly seated? (Initial beeping and WinAmp makes use of video if animations are displayed, especially in full screen )
ALso, can you hear windows sounds but not a cd? If so, check the audio cable going straight from the CDROM drive to the sound card.
cadetstimp is offline   Reply With Quote
Old December 31st, 2001, 08:33 PM     #9 (permalink)
Fur ballin
Sixpac_XP's Avatar
1. turn off computer
2. remove the sound card.
3. reboot computer normally into O/S
4. remove all references of the sound card that you can find.
5. shut down computer and re-install sound card into a differnet slot.
6. start up up and re-install sound card drivers (don't use the ones from the windows CD... get the latest ones from the manufacturer...)
7. reboot and it should work..
edit: (oh and when putting the cards back into their slot make sure you carefully rock them back and forth (carefully) into the slot making sure that you don't damage the motherboard).
Let me know. 6pac
Old December 31st, 2001, 08:34 PM     #10 (permalink)
SPEEDO's Avatar
Shutdown, Remove the sound card, Then boot into safe mode and remove any sound devices that are in there!
Just another idea to try!
SPEEDO
Thread Tools
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Is It Just Me? (527)
Misery Loves Company... (1849)
Why Does the MOON Grow Bigger as It.. (18)
heatsink issue (10)
New Mobo (18)
UPGRADING C/D DRIVE TO 250GB & .. (14)
SSD's, RAID, and External Backup (7)
1 internet. 1 house. 3 computer. ho.. (13)
firewall (1)
C++ compiler suggestions (4)
Official World of Warcraft Thre.. (4529)
Programming question (2)
UPGRADING C/D DRIVE TO 250GB &a.. (14)
Ubuntu or Xubuntu....anyone!!? (7)
Building my first PC and need s.. (0)
PNY vs Gainward (3)
Linksys WRT54G (2)
