epox 8rda+ post code 1d help needed
Currently Active Users: 2748
Discussions: 201,000, Posts: 2,380,042, Members: 246,371
Old October 20th, 2003, 09:48 PM   Digg it!   #1 (permalink)
draboo's Avatar
Send a message via MSN to draboo Send a message via Skype™ to draboo
i am attempting to install a cd burner in my machine. all went well with the physical install,but when i fired it back up,i get a "BEE_BOO" sounding siren and a post code of either 1d or Id.
i disconnected the power supply,and all cables running to the burner,so its back to its original state. i also cleared the cmos. still getting the siren and the post code. i watched the code and it goes past the memory code(C1),but stops when it gets to 1(or I)d. i looked in the manual and cannot find any info on this post code.
its a epox 8RDA+/xp1500/512mb ram/win xp pro.
any thoughts??
thanks,eh??
brad
edit: i have since found out that something is a bit goofy with my case fans. i rehooked the case fan up (smartfan) to its original setup,and i cant get any power to the machine whatsoever. wheni hit the power button,i can see the cpu fan turn the slightest amount,but nothing else.
so i hooked up the same fan directly to the mobo,which i assume is the way it was supposed to be in the first place. then i get the above post code. the original(and functional) way i had that fan originally was a jumper from one of the many power outlets i have floating around inside. the jumper came with the case fan and worked fine till tonite.
getting confuseder the further i go
draboo is offline   Reply With Quote
Old October 23rd, 2003, 07:46 PM     #2 (permalink)
Vyx
Vyx's Avatar
Send a message via AIM to Vyx Send a message via MSN to Vyx Send a message via Skype™ to Vyx
My advice, if you bought it from newegg. is to send it back and they will refund you and you can choose a new mobo. I had this motherboard for about a month, it just like falls to pieces after that. I sent rma'd it and they didnt carry that mobo anymore so just get a new one, it will save you so much trouble. That motherboard has so many issues.
Gi | Yuu | Jin | Rei | Makoto | Meiyo | Chuugi
Vyx is offline   Reply With Quote
Is It Just Me? (3126)
‘Rogue’ or ‘Rouge’? (10)
Foxconn Blackops x48 MoBo (5)
Nvidia GTX 260 problem (14)
Delete an OS (18)
Internet Lost (5)
System restore :) (1)
add ram to existing (4)
Delete an OS (18)
Print spooler problem (17)
Q9650 vs. Q9550 (2)
soundmon.exe (8)
Jedi Academy Problem (3)
