System will not boot P2B-B  | |
November 1st, 2003, 04:55 AM
Installed an ASUS P2B-B mobo w/powerleap1.0ghz and 96mb memory. After installing cards, drive w/xp etc. The computer will turn on but will not boot the screen remains black and wont even boot to the bios. Tried to press del and still cant enter bios. used another card for the monitor and still nothing????? |
November 1st, 2003, 02:46 PM
Anyone have any ideas or is this a dead board. I purchase from matrix.com and belive it was a bogus sale!!! |
November 1st, 2003, 02:53 PM
Have you checked all the jumpers etc??
That powerleap deal sort of adds a little confusion....did it come with instructions about fsb etc.
Go here and download the manual and check all the jumpers..there are several if I remember http://france.asus.com/support/downl...-B&Type=Latest
Are you saying you NEVER got it to boot? Or you installed XP and THEN it wouldnt boot??
You might have to try to disconnect everything off the motherboard except the cpu, vid card, one stick of ram and try to boot like that to see whats up.
Disconnect floppy cables, ide cable, modems etc.
JP
November 1st, 2003, 10:53 PM
I have checked all the jumpers on the mobo however not the jumpers on the processor.
The hard drive already had XP loaded and I inserted the XP disc it acted as if it was going to do something but screen just stays black.
I can not access the bios or the dos system to even run any of the prompts.
I will check the CPU jumpers. |
November 1st, 2003, 10:55 PM
I have an ASUS manuel and It will not boot at all. Hard drive will boot on another computer. |
November 1st, 2003, 11:13 PM
The PowerLeap does confuse the issue, but, if you have stripped the system back to just CPU, video card and 1 stick of RAM, are you getting any beeps when you power up? A series of short beeps usually indicates bad RAM, and a long one usually indicates bad video.
Also, the PowerLeaps sometimes require that the very latest BIOS revision be present in order to work.
November 1st, 2003, 11:14 PM
"the hard drive already had XP loaded"
well, if you are just switching the same hard drive back and forth it will be problematic.
what about safe mode?? |
November 2nd, 2003, 01:54 AM
How does one load the latest BIOS when it will not boot at all. tried a flash disk but will not boot from floppy. Hve striped it down and get no short or long beeps. Computer just runs with nothing on the screen. |
November 2nd, 2003, 02:02 AM
When computer starts NOTHING appears on the screen,
No BIOS, No system checks, No errors, Just black empty screen
Motherboard Blues |
November 2nd, 2003, 02:04 AM
have you tried another vid card?
Do you have any spare parts laying around? Even an old spare P2 would help troubleshoot the situation. |
