January 4th, 2002, 01:27 PM
| Does my new case have enough power?
Hi all,
I just won a dutch auction on ebay for a 300w atx case.. paid 25 bucks including shipping.
Well, it arrived today, it's nothing fancy, but if it works, hey, the price is right!
Anyway, i am wondering about the amperage of the ps. I have heard that the new XP chips have to have a certain amount of power? I am getting ready to build a new system, was going to use this case.
On the ps it says
King Star
Model: KC-300 ATX
Output: 300w max
+5v 35A
+12v 12A
+5vSB 1.0A
+3.3v 14A
-12v 1A
-5v .5A
Is this enough power?
drojman
January 4th, 2002, 01:35 PM
I would replace the PS with at least a 400w maybe a Enermax or Antec PS they cost more but its worth it |
January 4th, 2002, 01:50 PM
You could also go to AMD's website and search the name of the power supply to see if it is on the "approved"list for the processor that you have.
If not, you might need to find one that is compatable.
I would think that if you wanted to try that supply it might work, but if you start having system problems with the XP, you will have to find another power supply.
just float "power supplies" on their(AMD's) search and it should show a table for the XP processors
January 4th, 2002, 01:58 PM
It really depends on how many other devices you are running in your computer, and how much power they require. I ran my Athlon 1.33Ghz on a 250W power supply with 2 HD's, DVD-ROM, CDRW, Voodoo 3 2000, Modem, SB sound card, and 2 case fans for about 6 months with no problems before the PS finally gave up.
I would say give it a shot. If it doesn't work properly then go buy an Enermax (that's what I replaced mine with, works great!). It doesn't hurt to try.
Orb |
January 4th, 2002, 02:04 PM
Most 300W supplies support AMD XP up to 1900+
It just depends if you hooked allot of other stuff on the PS like fans, drives, case mods and so on. For normal use it would be suitable. |
January 4th, 2002, 02:11 PM
I won't be running too much stuff I don't think,
heres what i am going to build
epox 8kha+ mobo
XP 1700+
512mb crucial ram pc2100
geforce3 ti200
linksys nic
sb live
sony cdrw
40gig 7200 rpm hd
floppy
of course, mouse, keyboard,etc..
for usb I have a wingmaster force3d joystic that plugs in for its own power
have a usb netcam I use once in a while...
on my old k62 system, my ps is only 250 watts, been running everyday for over 2 years, working great... |
January 4th, 2002, 04:11 PM
i'd be carefull especially running a cd-rw and a geforece card and a 7200 rpm hard disk these puppies draw a lot of current. personally i'd go for it as ive run more than you have on a 300 with out any problem. |
January 4th, 2002, 04:51 PM
I recently upgraded my moms computer from a PII 450 to a Duron 900@1008 in a Micron case with a 200w PSU and it's been rock stable since the day I fired it up.. No probs since I've taken it back to her and my brother is on it everyday so I must say I'm very impressed with 1) Micron's case design made the upgrade very very easy no probs at all. 2) The quality of their PSU seeing how it's still going strong. |
January 4th, 2002, 04:57 PM
I'd say just try it, and it if doesnt work, just get a new one |
January 4th, 2002, 05:08 PM
| | Canuck
Will 300 watt support:
3 7200rpm HD's
Athlon XP 1600+ @ 1900+
GF2 MX400
CD-Rom
NIC
DV500 card....
along with12 fans..
- Freaky
