system idle process?
Currently Active Users: 1766
Discussions: 200,924, Posts: 2,379,110, Members: 246,290
Old November 15th, 2003, 06:25 PM   Digg it!   #1 (permalink)
operative x's Avatar
My computer has been lately running so damn slow so i checked the processes tab and at the bottum it says 'system idle process' taking 80% of my cpu. Can anyone help?!?!??! plz!!
operative x is offline   Reply With Quote
Old November 15th, 2003, 06:27 PM     #2 (permalink)
Best To Avoid Me
Martoch's Avatar
That just means that 80% of your cpu is available while it is idle, nothing is utilizing it at the moment...not a bad thing.
Martoch is offline   Reply With Quote
Old November 15th, 2003, 06:29 PM     #3 (permalink)
sam
sam's Avatar
thats nornal , just means that your computer is at idle, other process are using 20% and 80% is at idle(not being used)
sam is offline   Reply With Quote
Old November 15th, 2003, 06:38 PM     #4 (permalink)
DANM! well that sucks now i have no leads to why my computer just suddenly got so amazingly slow...
Old November 15th, 2003, 06:51 PM     #5 (permalink)
MrPurple's Avatar
Send a message via AIM to MrPurple
my system has started to run slow too. I would sugest on defraging (yes you still should do it once in a while if you are using NTFS), running a spy ware clean up utility would be good too. Also run a registry clean up utility.
Only other thing is to check the processes you have running and check how much RAM they are taking up.
-=Marcin=-
MrPurple is offline   Reply With Quote
Old November 15th, 2003, 06:59 PM     #6 (permalink)
Send a message via AIM to Gettinbye
That's not the reason your computer is running slow-in fact, all that is telling you is that your computer is at 20% load. That's not a bad thing. As far as slow performance, have you done a disk cleanup and defrag in a while?
*EDIT* oops, little slow on the typing...
4200+x2,a8n-sli premium,2gig pc3500,7800gt,7x sata hdds (160gig-320gig),2x dvdrw,630w psu,gigabyte aurora
Gettinbye is offline   Reply With Quote
Old November 15th, 2003, 07:21 PM     #7 (permalink)
Instigator
Atomic Rooster's Avatar
Send a message via AIM to Atomic Rooster Send a message via Yahoo to Atomic Rooster
Hey cool. I always wondered what the "System Idle Process" was. Thanks alot. Just goes to show ya you learn something new every day.
Atomic Rooster is offline   Reply With Quote
Is It Just Me? (2858)
Obama the Muslim (14)
Optical Audio A-B Switch (0)
Fire in DVD (0)
Virus Doctor Popup? (1)
SIS 740 and Widescreen (8)
