upgraded cpu on laptop but laptop fan comes on but it does not boot, HELP!!!!
Currently Active Users: 1588
Discussions: 200,506, Posts: 2,374,393, Members: 245,829
Old November 21st, 2003, 10:49 PM   Digg it!   #1 (permalink)
I got a laptop, it a solo 2150 version 1.5. It has a 600mhz mpga2 on it. When I upgrade it to a 800mhz, everything power up except the screen and it does not boot. I put the 600mhz back in and it boot. Then try with a 700mhz and it does the same thing as the 800mhz. I checked gateway and it same it support the 700mhz. Any suggestion will be helpful. Help!!
markel is offline   Reply With Quote
Old November 23rd, 2003, 02:11 AM     #2 (permalink)
imac9556's Avatar
Send a message via AIM to imac9556 Send a message via MSN to imac9556 Send a message via Yahoo to imac9556
hi,
is your bios on the lappy flashed to the latest version from gateway? sometimes, have you tried a CMOS reset? (i'm not sure if a lappy can reset a CMOS...)
thanks
imac9556 is offline   Reply With Quote
Old December 15th, 2003, 11:26 PM     #3 (permalink)
Unhappy
I flashed the bios to 17.52 for solo. It did the same thing as above. Any other idea would help.
Old September 10th, 2007, 02:08 PM     #4 (permalink)
TOAD6147's Avatar
Send a message via ICQ to TOAD6147
Yes you need to reset the BIOS so you can tell it you have changed to a different CPU. The older BIOS types did not do this automatically. During the initial boot screen, you should hit the either the Delete or F2 key in most cases to enter the BIOS.
foolish their lack of understanding."
Ambrose Bierce
TOAD6147 is offline   Reply With Quote
Is It Just Me? (1635)
Review My Build (5)
My 1st pc build (40)
Aero in Vista (7)
How to Ship a PC (16)
slaving laptop drive (7)
Review My Build (5)
2009 Build (4)
hard drive problem (2)
Hard Drive test program (2)
New Linksys Routers (2)
Mic won't work. (2)
