Hi all
I just got this message from a mate, which I wonder if anyone could suggest what he could try to sort out his problem...he is running Windows 98 second edition.
" I bought a compact flash card reader, I connected the device to a USB port and Ignored the software installation set up prompts. (I thought it might be a plug & play)
When I insert the software disk and try to install a pop up box tells me the software is already installed and I can progress no further.
If I go into the add & delete I can see "USB storage reader device" I delete it but when I try to reinstall the software again, it again says already installed.
I tried the above numerous times and have also restarted the PC. "
Thanks if anyone can help him out
Steve
