i can't get this mobo do do much, i connect everything and i flip the power, and it powers up fine but it gives half power to onboard fans, no video signal, no nothing, plz help, i hope it isn't dead.
hmm well half power to fans leads you to think under powered ps but to start you can pull all but thre essentials. CPU+hs/fan memory and video card place the mobo on a phone book outside the cae and see if it posts
"The true measure of a man is the degree to which he has managed to subjugate his ego."
