Join TechIMO for Free!
Topic: I have an IBM NteVista running Windows Millennium. One night I turned off my computer, came back the next day, and THIS is what it said when I booted.... "Windows may be unable to process the registry. This may be fixed...
Currently Active Users: 1889
Discussions: 183,226, Posts: 2,189,277, Members: 226,008
Old December 19th, 2003, 09:16 AM   Digg it!   #1 (permalink)
PLEASE HELP!!! REGISTRY problem
"Windows may be unable to process the registry. This may be fixed by rebooting to the Command Prompt Only & running SCANREG /FIX. Otherwise there may not be enough free conventional memory to properly run the registry."
Then suddenly it shift into normal mode.
How can I reboot to Command Prompt Only? Will this work? What the hell is a registry?
Please help....thanks
kevincassels is offline   Reply With Quote
Old December 19th, 2003, 09:30 AM     #2 (permalink)
Jarhed7276's Avatar
Hi Kevin,
To boot to Command Prompt continually hit your F8 key while rebooting. This should take you to a menu where you will be given the choice of booting to a command prompt. Once at the prompt type in Scanreg /fix.
Will this work? Only God and Bill Gates knows.
The registry is a system data base that holds information that tells your pc how to boot up and what programs to load on bootup.
Hope this will help you. Good luck.
Gerry
Jarhed7276 is online now   Reply With Quote
Old December 19th, 2003, 09:33 AM     #3 (permalink)
HeadBand's Avatar
if it can get to normal mode doing a system restore can do the same thing with a more userfriendly enviornment...just go back to when it was working properly
Hey who turned sigs on?
Old December 19th, 2003, 09:41 AM     #4 (permalink)
Supporting our military
Bill in SD, CA's Avatar
I didn't know ME had a system restore.
Gerry's advice should work.
Bill
Welcome to TechIMO BTW!!
Bill in SD, CA is offline   Reply With Quote
Old December 19th, 2003, 09:59 AM     #5 (permalink)
HeadBand's Avatar
yes ME does have a system restore but you might have to install it in add/remove windows programs or whatever its called
Old December 19th, 2003, 10:09 AM     #6 (permalink)
Let's go, Hokies!
osprey4's Avatar
System restore is installed by default. It will run in safe mode or normal. But if your registry is corrupted due to a corrupted file, it may not work.
Boot using a Boot Disk, and run the registry repair from the command prompt.
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Manmade CO2 Driven Climate Change (14)
Palin Should Strike Fear in Democra.. (21)
Is It Just Me? (11040)
Obama learning from Biden? (15)
Serving your Country (124)
Would you expect anything less from.. (8)
amd athlon 64 X2 5000+ be not r.. (2)
DO I HAVE THE POWER??? **PLZ HE.. (11)
Photoshop not allowing me to pi.. (2)
8800 GT SLI NOT SCALING WELL :/ (0)
my 8800GTS SLI AMD X2 6400 only.. (12)
I cannot comprehend whether my .. (1)
Memory question, duh! (5)
Image Changing With Javascript? (5)
Random Game lag? (3)
FS: HP Pavilion dv8000 Notebook (6)
Fable 2 Pub Games and Xbox Live.. (1)
looking for laptop (2)
