Join TechIMO for Free!
Thread Tools
Currently Active Users: 2517
Discussions: 188,390, Posts: 2,243,543, Members: 232,619
Old December 20th, 2003, 04:37 AM   Digg it!   #1 (permalink)
Bios settings problem
Hi,
when my computer starts up it enters the AwardBios Setup Utility.
These are the settings:
CPU speed [Manual] - on the right it says during the last boot-up, your system hung for improper frequency combination. Your system is now working in safe mode. To optimize the system performance and reliability, make sure the frequency combination conforms to the specification of your CPU, DIMM and other connected devices.
CPU Frequency Multiple [12.5x]
CPU External Frequency (MHz) [200/40] - on the right it says Caution: According to CPU external frequency setting, system memory can only operate at frequency higher than or equal to 333MHz. Please make sure the DRAM max frequency is not less than 333MHz
Memory Frequency [Auto]
CPU Vcore Setting [Auto]
CPU Level 1 Cache [enabled]
CPU level 2 Cache [enabled]
OS/2 Onboard Memory > 64M [disabled]
I tried the set up defaults (F5) and saved and exit, but then the monitor just goes on standby mode and I have to unplug the computer to switch it off.
I would phone the helpline, but it's only there Mon - Fri.
You guys are my only hope!!
Deadlifter is offline   Reply With Quote
Old December 20th, 2003, 04:42 AM     #2 (permalink)
DallasDon's Avatar
set the cpu speed to "auto" or "SPD", and the system should boot at the rated speed of the cpu/ram.
DallasDon is offline   Reply With Quote
Old December 20th, 2003, 04:55 AM     #3 (permalink)
the cpu speed options are
Manual
1250Mhz
1667Mhz
2083Mhz
2500Mhz
there is no auto option
I forgot to tell you my sys specs:
Athlon XP 2800 Barton 512MB Cache
Mem 2*512Mb PC2700 DDR
HD 120Gb
Graphics GeForce4 FX5200 256MB 8X TVO DVI
Audigy 2
Win2000 Pro
Asus A7V8X-X Mobo
Old December 20th, 2003, 05:19 AM     #4 (permalink)
DallasDon's Avatar
The pc 2700 runs at 166, so I would set it at 2083 (divided by) 12.5 = 166 mhz. That is "double pumped" to achieve 333 mhz.
Old December 20th, 2003, 05:31 AM     #5 (permalink)
Thanks DallasDon.
That worked!
Have a good weekend.
Old December 23rd, 2003, 04:24 AM     #6 (permalink)
Unhappy
I too have that problem!!!
Hello guyz!
I too have that problem... my system does'nt boot, and whenever it does, it goes into the Award BIOS Utility and the error message is " Your system hung for improper frequency combination" . My processor is Intel Pentium 4 1.7 GHz, and I have a 128 MB DDR RAM. I tried the Auto setting, I tried 100 MHz x 17x multiple but they don't work.
Please help...
Problemguy.
problemguy is offline   Reply With Quote
Old December 23rd, 2003, 04:35 AM     #7 (permalink)
HeadBand's Avatar
what speed ddr ram
Hey who turned sigs on?
Old December 23rd, 2003, 05:19 AM     #8 (permalink)
DallasDon's Avatar
Don't know P4 that well, but that multiple sounds way too high.
Try to load "performance defaults" in the voltage control page, save and exit.
Old December 23rd, 2003, 05:27 AM     #9 (permalink)
HeadBand's Avatar
no 100x17=1700 or 1.7 GhZ i am thinking it is too fast of ram for the mobo
Thread Tools
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Is It Just Me? (2899)
Building a gaming computer advice (5)
New Build ( Finally ) (6)
CPU wont boot (7)
3-days in and no threads about Gaza (160)
The United States Debt (21)
Upgrading RAM (6)
Folderchat Weekday thread (444)
nVidia GTX 295 now available (0)
BATCH FILE WONT OPEN!!! HELP!!! (4)
Cell phone interferes with pc s.. (10)
upgrading video card and psu he.. (8)
Possible solutions for burnt-ou.. (9)
Left 4 Dead Small Freezes (0)
Netgear HDX101 Powerline HD Eth.. (3)
Core 2 Quad Q9550 system (3)
