Emachine Power Switch Problem?
Currently Active Users: 2620
Discussions: 200,520, Posts: 2,374,498, Members: 245,842
Old January 13th, 2004, 05:04 PM   Digg it!   #1 (permalink)
Hi,
I am new here. I searched the backposts,but didn't see my exact problem.
A friend of mine asked me to look at her computer. It will turn off using the power button,however it will not turn back on. It will come back on if you unplug the power cord,and then plug it in.
It is a 433i,running Win98SE. It seems to boot fine,and is running like normal. Is it just a bad switch,or is something wrong with her settings somewhere? Thanks for any help.
Christy
Texaslady is offline   Reply With Quote
Old January 13th, 2004, 05:26 PM     #2 (permalink)
implexant's Avatar
Send a message via ICQ to implexant Send a message via AIM to implexant Send a message via MSN to implexant Send a message via Yahoo to implexant
I'm guessing it's the power switch. You probably can't replace it with an exact one, so you'll have to rig something using other electrical parts.
Other people around should be able to help you out with that
BTW, Welcome to TechIMO!
-Chris
implexant is offline   Reply With Quote
Old January 14th, 2004, 12:05 AM     #3 (permalink)
Christy, I am retired from industrial electronics, and have repaired a few computer power supplies. I know how a standard AT (old type) and ATX (newer type) power supplies. emachines are ATX technology I think, but not sure as I have never seen one.
But for right now, let me tell you a little bit about how an ATX power supply works, and why I don't believe the problem could be the power switch.(well..maybe it could be).
The on/off switch on any ATX type computer acts like a doorbell or horn button on an automobile. It only works as long as you mash it down...release the button, and the bell or horn stops.
In an ATX power supply, there is two supplies in one housing. A 5 volt part that is always on..there is no way to turn it off by a switch. It is powered on as long as the computer is connected to the AC power source, i.e. the wall plug in socket.
This extra 5 volts is used to turn the main power on and off by way of the case "momentary" switch...if this switch goes bad, it will not turn the computer on or off..unless it is partially shorted, and the computer remains in the off position and held in this state until all power is removed and the circuits are returned to their normal state..then by re applying the AC power, the system will again turn on.
I have only heard of this happening one time, but that may be exactly what is going on in your friends computer..if in fact an emachine follows ATX technology.
If that emachine has a reset button, have some one (or yourself if you are hardware able) swap the reset switch for the on/off switch..they are identical switches and exchange readily. If this fixes the computer, then try to replace the switch with a generic one if a direct replacement is not available.
Bovon is offline   Reply With Quote
Is It Just Me? (1660)
HELP!!! What do you think of this s.. (25)
windows 7 retail and rtm (5)
Review My Build (6)
My 1st pc build (40)
Aero in Vista (7)
[F@H SPAM 11/1/09]New month . . . n.. (34)
slaving laptop drive (7)
[F@H SPAM 11/08/09] Where has all the.. (1)
nvidia geforce 9500GT 1gig DDR2 (3)
[F@H SPAM 11/1/09]New month . . . new.. (34)
Endless BSOD to Recovery Manager loop.. (0)
HELP!!! What do you think of this sys.. (25)
New Processor, Monitor will not turn .. (3)
Determining ip route and serial addre.. (8)
can u beat freecell # 1941? (11)
Dell 8300 Graphics Problems (1)
Powe Director v8 (0)
Review My Build (6)
2009 Build (4)
