oversized harddrive problem
Currently Active Users: 2429
Discussions: 200,941, Posts: 2,379,267, Members: 246,304
Old February 8th, 2004, 04:09 AM   Digg it!   #1 (permalink)
sup3rcarrx7's Avatar
Send a message via AIM to sup3rcarrx7
Hi guys. I'm having trouble trying to get my 250gb maxtor to show up as a actualy 250gb hdd or up. I'm on windows 2000 pro and already on sp4. Here's the list of things i did so far and a pic of the partitions i have right now in partition magic if that helps. Thanks.
1) Installed Windows 2000 on a 15gb partition taken from the 250gb total.
2) installed sp4 for windows 2000.
3) installed partiton magic pro 7 and saw only the following picture. It shows the additional other 120 or gigs in the blue area and not pink. Partiton magic only let me make a 113gb partition.
Please help me out here guys! I bought a 250gigger for no reason if i can't use the other 100gb! Thanks for any help.
Hi there.
Current Rig:
Abit NF7-S v.2.0
AMD Athlon XP 2500 (watercooled with maze 3)
1GB DDR400
Ati Radeon 8500 LE 128MB
Buslink DVD±RW
DVD ROM 16x
250GB WD
2x 120GB Maxtor (both died)
Dual Psu'ing with one generic 500watter and one Antec 300watter
Heatware: sup3rcarrx7
sup3rcarrx7 is offline   Reply With Quote
Old February 8th, 2004, 04:18 AM     #2 (permalink)
bfcx's Avatar
Did you get a PCI card with your drive? You'll need a ATA133 card that knows how to address that much space, right now your computer doesnt know how to see past 120Gigs. This is a hardware problem, not software.
Hope that helps
bfcx is offline   Reply With Quote
Old February 8th, 2004, 04:27 AM     #3 (permalink)
I don't get what you're saying though. My mobo is a abit nf7-s and it already has ata133 with it onboard. And no, the 250gb drive is not in a sata port.
Old February 8th, 2004, 05:23 AM     #4 (permalink)
Xtreeme's Avatar
From what I remeber of fat32 limitations.....
Need NTFS for SINGLE partition over 120gig or so. You can have two partitions and use in 2k. Or use 1 with ntfs and XP.
R.I.P. TKOP
Xtreeme is offline   Reply With Quote
Old February 8th, 2004, 07:04 PM     #5 (permalink)
Nevermind guys. I got it working now with that registry edit tweak. Thanks.
Old March 16th, 2004, 01:13 AM     #6 (permalink)
If I read you correctly. You need to add another pci card :ata133 for the maxter 200 gig to work. The maxter software will let me partition the hd prior to installation. XP does not see this operation and wants to format on 32 gig. Now the system see only 32 gig of the 200g system. Do we have to start all over again after installing the ata133 or will it see the hd and allow me to format further. The software that maxter loads for XP will not allow you to format any further past what windows has performed. E-Mail me please. I may not be able to get back to this forum on this computer. jwalton@jkwenterprise.com.
tks.
orgpanamajoe is offline   Reply With Quote
Is It Just Me? (2912)
Wireless Televisions. (8)
Regular Build (6)
Obama the Muslim (14)
sms storage to PC (0)
Regular Build (6)
Open With ..... Win7 (0)
java code for fibonacci (1)
screen resolution vs monitor size (0)
Have you switched yet? (85)
Modern Warfare 2 freeze (13)
wireless user (1)
favorit (1)
Fire in DVD (2)
