Results 1 to 8 of 8
Thread: photoshop help!
    Exclamation photoshop help!
    I'm working on a project that is due tomorrow and in the link below shows you what Im having trouble fixing. Like the blocks I made that i put beside each other is not smooth and i want it to look smooth. I circled the tool I used and circled the stuff that are not smooth.
    Please help! Btw I'm using Photoshop CS3 Extended Version.
    bump!
    bump for the helpp
    Ultimate Member Vyx's Avatar
    May 2003
    Cheyenne, WY
    1,093
    Maybe instead of bumping every 20 minutes you should play around with it and try to figure it out...
    I would try fiddling with which layer is on top and also doing some careful aligning of the shapes.
    Gi | Yuu | Jin | Rei | Makoto | Meiyo | Chuugi
    Jan 2003
    Outside the box
    8,700
    4
    they aren't aligned properly because you are beveling and embossing them. If you are trying to create one uniform shape the merge the additions with the existing layer you want it merged with then add the effects
    Be a Liberal, blame everyone else!!
    Nevermind I got it Thanks SOOOOOOOO MUCH!
    Member mistabyggs's Avatar
    Jun 2007
    Kentucky
    67
    I was going to add that even if he beveled and embossed one layer, all he has to do is drag that layer to the new layer icon and it will create an exact copy with the effects. Then all he has to do is click the move button an use the "directional keys" on the keyboard to move it straight across from the position of the shape on the first layer. But, he already solved the problem....LOL
    (.*`*- ->MistaByggs
  1. Need help with photoshop
    By EXreaction in forum Web Design, Development, Graphics, Photography
    Last Post: September 14th, 2005, 10:56 AM
  2. photoshop help......help!help!
    By moo in forum Applications and Operating Systems
    Last Post: June 26th, 2004, 08:37 PM
  3. Photoshop help.....help! help!
    By moo in forum IMO Community
    Last Post: June 26th, 2004, 12:03 PM
  4. Photoshop Help (stoopid photoshop!)
    By Master Chief in forum Web Design, Development, Graphics, Photography
    Last Post: June 15th, 2004, 07:57 AM
  5. How can i do this in Photoshop?
    By Fade2Grey in forum Web Design, Development, Graphics, Photography
    Last Post: December 11th, 2003, 10:28 PM
