Need some easy Java Help
Currently Active Users: 1727
Discussions: 200,950, Posts: 2,379,461, Members: 246,312
Old May 15th, 2004, 09:25 PM   Digg it!   #1 (permalink)
Gib
Hello,,, well I am learning java in school and the teacher is terrible, I have a hw assignment I have no idea how to do.
I have to finish writing the code to this program. the question is.
"The BMI applet computes a persons body mass index. BMI Applet is defined as the weight, in kg divided by the square of the height, expressed in meters. A fragment of the BMI applet is show below.
import java.awt.*;
import java.awt.event.*;
import javax.swing.*;
import java.text.DecimalFormat;
public class Bmi extends JApplet
implements ActionListener
JTextField inputLbs, inputInches, displayBmi;
public void init()
JLabel labelLbs = new JLabel("Weight (lbs):", SwingConstants.RIGHT);
inputLbs = new JTextField(5);
JLabel labelInches = new JLabel("Height (inches):", SwingConstants.RIGHT);
inputInches = new JTextField(5);
JLabel labelBmi = new JLabel("BMI = ", SwingConstants.RIGHT);
displayBmi = new JTextField(5);
displayBmi.setEditable(false);
JButton go = new JButton("Compute");
go.addActionListener(this);
Container c = getContentPane();
c.setBackground(Color.white);
JPanel p = new JPanel();
p.setLayout(new GridLayout(3, 2, 5, 5));
p.add(labelLbs);
p.add(inputLbs);
p.add(labelInches);
p.add(inputInches);
p.add(labelBmi);
p.add(displayBmi);
c.add(p, BorderLayout.CENTER);
c.add(go, BorderLayout.SOUTH);
public void actionPerformed(ActionEvent e)
int lbs = Integer.parseInt(inputLbs.getText());
int inches = Integer.parseInt(inputInches.getText());
double bmi = calculateBmi(lbs, inches);
DecimalFormat df = new DecimalFormat("00.0");
displayBmi.setText(df.format(bmi));
private double calculateBmi(int lbs, int inches)
< ... missing code >
I have to supply the missing code for the calculateBmi method, which takes weight in lbs and hight in inches as arguments and returns the body mass index...
ANY ideas here thanks/..
Gib is offline   Reply With Quote
Old May 17th, 2004, 03:26 AM     #2 (permalink)
Tekk's Avatar
Ok well I just had to rewrite this because I thought you had to create and actionPerformed method but apparently its already created!!!!
Actually this problem is very easy:
All you need to do is write a few lines of code that do all the calculations of the lbs and inches that the method is taking. For instance, if the bmi was found by adding lbs and inches then the code for that method would look as follows:
Code:
      double total = lbs + inches;
      return total;
OR YOU CAN DO IT DIRECTLY...
      return Double.parseDouble(lbs + inches);
Not too difficult. Just use that same methodology but you'll need to use the correct way to find the Bmi.
YAH! I knew you'd be jealous
Tekk is offline   Reply With Quote
Old May 17th, 2004, 04:53 AM     #3 (permalink)
Retired mostly.
I don't know anything about java or your problem, but why are you using pounds and inches when it says at the top that it has to be kilograms and meters?
Old May 17th, 2004, 01:42 PM     #4 (permalink)
Tekk's Avatar
the teacher obviously wants them to do some conversion.
Old May 17th, 2004, 06:48 PM     #5 (permalink)
Gib
Thanks a lot Tekk
Old May 18th, 2004, 12:09 AM     #6 (permalink)
Tekk's Avatar
no problem...lemme know if you need any more help
Old May 19th, 2004, 12:35 AM     #7 (permalink)
Creosote is offline   Reply With Quote
Old May 19th, 2004, 12:47 AM     #8 (permalink)
Now in the nicer ghetto
butch81385's Avatar
Send a message via AIM to butch81385
EDIT due to other EDIT. nothing to see here, move along people
I don't like signatures.
butch81385 is online now   Reply With Quote
Old May 19th, 2004, 02:05 AM     #9 (permalink)
Tekk's Avatar
who you replyin to butch?
C++ or Java? shawshank62 General Tech Discussion 17 February 25th, 2004 01:04 PM
Opera 7.21 brian0555 Applications and Operating Systems 7 November 2nd, 2003 11:36 AM
Looking for samples how to write an IRC client in C# gicio Webmastering and Programming 3 December 10th, 2002 01:39 AM
programmers wewtupdawg Applications and Operating Systems 4 August 14th, 2002 02:42 AM
Microsoft Java Virtual Machine Shoes General Tech Discussion 2 August 2nd, 2002 08:07 PM
The disrespect of Obama by Russian .. (39)
Is It Just Me? (2941)
Making Health Care Worse (177)
Regular Build (9)
Print spooler problem (15)
Dept. of HS: NSA 'Helped' Develop V.. (16)
Regular Build (9)
Internet Lost (3)
Virus advise (7)
EVGA 9800 gtx help with finding a goo.. (10)
Modern Warfare 2: Who Bought It? (62)
How to convert MP3's (4)
Asus P4G8X Mobo (6)
Have you switched yet? (86)
