Results 1 to 4 of 4
    Aug 2004
    10
    regsvr32 ...module not found
    I am trying to register a new .ocx file in the system32 folder. So far if using the command line : regsvr32 c:\windows\system32\ISS****.ocx has worked on 2 computers. I get a failure to load on all the rest I have tried. The file is in the system32 folder but the "regsvr32" does not find it. I can enter the name of the very next file beside it and it works OK on that file. Even our IS dept. has the same result, any other file will register except the one listed above. All the copied files all come from the same storage location on our server. So what am I missing?? On the pc's that work I can either use the command box or from a command prompt box to register and both work either way.
    Dec 2004
    1,558
    Is it on Windows XP with IIS 5.1, Windows Server 2003 with IIS 6, or are you using Apache?
    Aug 2004
    10
    The incividual PC's
    The pc's all run XP-Pro with SP2, I went through a few more yesterday only to discover that the only 2 machines that will register the .ocx file are mine and the production manager's. So far about 10 others will not find the module .ocx file. IIS is installed on my desktop but it's not part of this application, it is for another SCADA app. I am developing.
    Dec 2004
    1,558
    Alright, I don't remember exactly what the fix is but I know I've seen it somewhere so I'll let you know as soon as I can track it down again. It might take me a couple of days as I'm pretty busy right now.
  1. Internet Explorer problem
    By DoctorReno in forum General Tech Discussion
    Last Post: October 25th, 2004, 06:39 AM
  2. No javascript popups in xp pro/ie6 ???
    By ^hyd^ in forum Applications and Operating Systems
    Last Post: September 14th, 2004, 10:45 AM
  3. vbScript multi-line execution problem
    By SWarrior2k in forum Applications and Operating Systems
    Last Post: May 14th, 2004, 12:21 PM
  4. outlook express dead links in message
    By Rancher70818 in forum Networking and Internet
    Last Post: April 10th, 2002, 10:57 PM
