Java if statement problem...
Currently Active Users: 2776
Discussions: 200,970, Posts: 2,379,706, Members: 246,334
Old February 23rd, 2005, 09:37 AM   Digg it!   #1 (permalink)
Send a message via AIM to Blazer06
This is a very basic if statement in a much longer peice of code:
However, for some reason, it does not work. Can you see a reason why?
Code:
String strAccess = new String(rights1.getText());
if(strAccess == "1"){
	u1.setSelected(true);
	u2.setSelected(false);
	u3.setSelected(false);
strAccess will in fact = 1, but the if statement just won't run!
-Blaze
Blazer06 is offline   Reply With Quote
Old February 23rd, 2005, 10:00 AM     #2 (permalink)
Not Really a Member
The only thing that comes to mind is datatypes.
Not sure how java does it, it SHOULD treat that 1 as a string which is what you're comparing.. but the only that cames to mind is if its treating it as an integer whereas you'd want to test as strAccess = 1 (sans quotes)
You declared strAccess as a string, so I'd think it would convert whatever gets in as a string, but not sure if it will do that on the fly or if you need to do it explicitly.
vass0922 is online now   Reply With Quote
Old February 23rd, 2005, 11:14 AM     #3 (permalink)
I rewrote it to use spinners this morning, and got this code, which did the same thing.
Code:
String strAccess = new String(rights8SpinnerModel.getValue().toString());
	o1.setSelected(true);
	o2.setSelected(false);
	o3.setSelected(false);
So I musted around for awhile, and wrote this working code:
Code:
if(rights8SpinnerModel.getValue().toString() == "1"){
I'm still not sure why the later works and the former doesn't, but it works for now, and for now that's all I need.
-Blaze
Old February 23rd, 2005, 11:20 AM     #4 (permalink)
Eclipse is telling me that both are strings, no converting needed. Also, I can output strAccess, or set another text box to equal it or whatever the heck I want to do, but compare it to another string. See above post.
-Blaze
java virtual machine jervic Applications and Operating Systems 3 October 20th, 2004 11:20 AM
where to get microsoft virtual machine? dustinbob General Tech Discussion 23 March 1st, 2004 07:33 PM
java trouble dezzzi28 Technical Support 7 September 24th, 2002 09:33 PM
WinXP Pro and Javascript question bill1971 Applications and Operating Systems 6 August 31st, 2002 04:06 AM
can't update windows?? need som help please zskillz Technical Support 7 August 4th, 2002 05:16 AM
Is It Just Me? (3035)
Forty-six years ago today (12)
The disrespect of Obama by Russian .. (47)
Internet Lost (5)
Nvidia GTX 260 problem (4)
Steam ID's, Gamertags etc... (2)
Delete an OS (9)
Open With ..... Win7 (3)
Internet Lost (5)
virus blocking exe. files (1)
Print spooler problem (16)
webcam (0)
upgrade for hp a6101 (0)
