I need help to use asci codes
Currently Active Users: 2389
Discussions: 200,942, Posts: 2,379,318, Members: 246,305
Old March 25th, 2005, 11:11 AM   Digg it!   #1 (permalink)
i have an assignment to write c++ program that should be very easy but i am very new to write codes in c++. My topic is that encryption of "sweidon" and i ll replace each letter with the three places later in the alphabet. For example, Instead of writing "A" , i ll write "D" .... I couldn't find out how can i write it in codes.
i think i should use ASCI and i should add 3 upon the ASCI code to reach the encryption code.... how should i write to read all letters that is inclued in family name of "sweidon" ????
Tayfun is offline   Reply With Quote
Old March 25th, 2005, 11:20 AM     #2 (permalink)
Real gangstas sip on Yacc
jkrohn's Avatar
Send a message via ICQ to jkrohn Send a message via AIM to jkrohn Send a message via Yahoo to jkrohn
Read them in as characters. Then cast to ints.
char blah = 's';
int code = (int)s;
code += 3;
blah = char(code);
jkrohn is offline   Reply With Quote
Old March 25th, 2005, 11:28 AM     #3 (permalink)
so should i write for loop for other char, shouldn't i ? or i ll input the chr. one-by-one
Old March 25th, 2005, 11:28 AM     #4 (permalink)
jkrohn's Avatar
you should take input as a character array and loop through it.
Old March 25th, 2005, 11:31 AM     #5 (permalink)
all right then, i ll try immediatly... thnx so much
Old March 28th, 2005, 07:55 PM     #6 (permalink)
I am a banana!
originel's Avatar
Send a message via AIM to originel
you don't even have to typecast because a char is an 8-bit int anyways.
to shift it three places you just add 3 to it...it's that simple
Code:
char letter = 'A';
letter += 3;
letter equals 'D' after this. A little side note about characters, the syntax 'A' is just another way of writing 0x41. It's like a placeholder really and is actually an integer, and so you can do any integer stuff with a char (with the exception of passing to functions and some more complex memory stuff since it's 8 bits, not 32 bits).
originel is offline   Reply With Quote
Mafia Cheat Codes Question HansGroenewold General Gaming Discussion 33 August 5th, 2003 04:30 PM
Need Staples Coupon Codes Milan0007 ResellerRatings Homepage Deals 1 October 25th, 2002 06:21 PM
Promotional Codes? aznlurkerz ResellerRatings Homepage Deals 2 August 14th, 2002 01:11 AM
Has anyone ever seen coupon codes for www.dalco.com John Prophet ResellerRatings Homepage Deals 3 May 14th, 2002 06:41 PM
Staples coupon codes I_W ResellerRatings Homepage Deals 1 December 31st, 2001 07:56 PM
The disrespect of Obama by Russian .. (12)
Making Health Care Worse (153)
Is It Just Me? (2918)
Wireless Televisions. (11)
Regular Build (6)
Print spooler problem (15)
Have you switched yet? (86)
Asus P4G8X Mobo (5)
sms storage to PC (0)
Regular Build (6)
Open With ..... Win7 (0)
java code for fibonacci (1)
Modern Warfare 2 freeze (13)
wireless user (1)
favorit (1)
