VB Help with Void Null
Currently Active Users: 1515
Discussions: 200,952, Posts: 2,379,474, Members: 246,315
Old April 14th, 2005, 12:47 AM   Digg it!   #1 (permalink)
redfoxstorm's Avatar
I've wrote a small VB program that except input through a textbox. After I wrote the program I want to know what is the code that will allow me to print out an error message when nothing is entered?
How can do it with a if statment? Like
if textbox1.text = null then
"label1.text = " No Input"
End If
Thats all i want to do....can anybody help?
RedFox
For the Emperor, there were the Jedi. For the Evil Empire of Microsoft, there is a penguin.
redfoxstorm is offline   Reply With Quote
Old April 14th, 2005, 01:03 AM     #2 (permalink)
Perfetc Member
VHockey86's Avatar
isnt there an "isEmpty" method (function) or something?
Haven't used VB in awhile, but i dont see why this wouldnt work
if textBox1.text() = "' then
whatever
end if
Those are two quotation marks with no space inbetween them.
VHockey86 is offline   Reply With Quote
Old April 14th, 2005, 03:25 AM     #3 (permalink)
didn't work
Old April 14th, 2005, 03:52 AM     #4 (permalink)
I keep getting a "cast from string "" to Integer is not valid"
whats that mean?
Old April 14th, 2005, 04:32 AM     #5 (permalink)
Try:
Code:
If textbox1.Text = "" Then
label1.Text = "No Input"
End If
If that doesn't work, check your data types (in all your statements) because something is wrong there. That's what's causing the type cast error.
large_nostril is offline   Reply With Quote
Old April 14th, 2005, 10:48 AM     #6 (permalink)
Perfetc Member
VHockey86's Avatar
... is your textbox somehow like a "number box" ?
I agree, that is very weird. I would think that everything is treated as a string from a text box.
Perhaps what you need to do is stop the current function if that error occurs.
It's probably trying to use that data later on in your program execution since setting a label to "no input" never actually stops the rest of it from executing.
You probably want to do something like
If Not textbox1.Text = "" Then
//call a function to continue execution
Else
label1.Text = "No Input", (might also want to consider using a message box here, not so discrete)
End If
Another way around it would be to set
textbox1.Text = 0 if there is no input (so, in the else statement above).
Old April 14th, 2005, 11:02 AM     #7 (permalink)
ph34r t3h g04t
Whir's Avatar
In the button code, put this:
If txtbox1.Text = "" Then MsgBox "No Input"
Second, just setting a label.Text to a variable will not update the forum until you do a frmWhatever.Refresh (I think is the method - it's been a while).
Third, since this isn't a multiple line statement If, you don't need to get fancy with an End If. Just tack a MsgBox behind the Then and call it a day.
BTW, the MsgBox makes a pop up box. If you WANT the form to be updated (not how you would normally want the program to work), then you should do the lblLabel.Text = "No Input" and frmForm.Refresh inside a normal If, Then, End If.
Make sense?
Old April 14th, 2005, 11:07 AM     #8 (permalink)
ph34r t3h g04t
Whir's Avatar
isEmpty works if the variable is either set to empty, or the variable is uninitialized. Even if there's no input to the box, I believe it will still be "" rather than empty.
Old April 14th, 2005, 11:46 AM     #9 (permalink)
Send a message via AIM to Blazer06
The code that you would need to have is:
Code:
Private Sub subCheck()
If text1.text = “” then
	‘If there is no input
	Lable1.caption = “No Input”
Else
	‘If there is input
	Lable1.caption = “Input”
End if
End Sub
Then just call subCheck when you needed to check.
-Blaze
Blazer06 is offline   Reply With Quote
Old April 14th, 2005, 11:47 AM     #10 (permalink)
Not Really a Member
have you tried
If CStr(txtBox.Text) = "" Then
OR Worst case scenario
Dim vSomeVar As Variant
vSomeVar = txtBox.Text
If vSomeVar = "" Then
or even worster scenario (this shouldn't even work seeing as a text box can't handle a NULL value
If IsNull(txtBox.Text) Then
vass0922 is offline   Reply With Quote
Null and Void according to California Supreme Court FTM IMO Community 7 August 13th, 2004 01:16 AM
C++ question on void functions. Elburn Webmastering and Programming 6 February 12th, 2004 08:35 PM
Arctic Sillver will void your AMD warranty. Theophylact Processors, Memory, and Overclocking 13 April 30th, 2003 10:05 PM
redhat null: anyone know about it? storm2k Applications and Operating Systems 3 August 24th, 2002 01:55 PM
XML to void out the C language? newbie~wan Webmastering and Programming 31 April 2nd, 2002 11:41 AM
Is It Just Me? (2942)
Print spooler problem (15)
Virus advise (8)
Internet Lost (3)
How to convert MP3's (4)
Asus P4G8X Mobo (6)
