May 12th, 2005, 07:04 PM
| | The Macedonian Member
I need some Visual Basic help. I cant think of the code something I need for my program. When I press "Get Roster" I need it to pull all the info from a Text File and the place all the info into a Listbox, I cant think of the code Blaise helped me last night but i forgot to save the code and I lost It so I need your guys help.
TIA |
May 12th, 2005, 07:40 PM
May 12th, 2005, 07:49 PM
well Input as #1 but i want it to go into a Listbox |
May 12th, 2005, 07:51 PM
| | I am a banana!
there is a 'listboxname.additem("item name")' command you can use in conjunction with Input as #1 |
May 12th, 2005, 08:03 PM
| Quote: |
Originally Posted by originel there is a 'listboxname.additem("item name")' command you can use in conjunction with Input as #1 |
See how do i do that? I need it to add to the list |
May 12th, 2005, 08:18 PM
| | I am a banana!
here's an example: Code: dim myArray[arraysize]
'Code that will get the info from the file using the above methods
'i don't know how to do it off the top of my head and am too lazy to read up on it
for i = 0 to arraysize - 1
listboxname.AddItem(myArray[i])
loop Simple as that
(btw...better check syntax...i've been coding in C++ for the last two weeks and so I'm probably mixing the two syntax's). |
May 13th, 2005, 12:16 AM
I rarely use input as #1 not much control over it Code: Dim objFSO As FileSystemObject
Dim oInputFile as File
Set objFSO = New FileSystemObject
Set objFile = objFSO.OpenTextFile("C:\Somefile.txt", FOR_READING)
Do While Not objInputFile.AtEndOfStream
sCurLine = Trim(objInputFile.ReadLine)
If sCurLine <> "" Then
lstBox.AddItem sCurLine
End If
Loop
objInputFile.Close
Set objInputFile = Nothing
Set objFSO = Nothing something like that, but make sure to add Scripting Runtime as a reference to get the FSO available. |
May 13th, 2005, 12:19 AM
| Quote: |
Originally Posted by vass0922 I rarely use input as #1 not much control over it Code: Dim objFSO As FileSystemObject
End If
Loop
objInputFile.Close
See that looks like something ifce dones but never used al that stuff, Lets just say i havent learned anything in that Class |
May 13th, 2005, 12:29 AM
I pull off a lazy method where I load the file into a rich text box, use a bunch of loops to search for certain text, and then I do what I want with it. quite neat really
AMD Athlon 64 4000+ @ 2.6 GHz
MSI nForce4 SLI S939 @ 2000MHz FSB
OCZ 2GB PC3200 DDR RAM
BFG 256MB GeForce 7800GTX PCIe @ 460/1300
Like I remember something Code: Open App.Path & "\Roster.txt" For Random As #1(I think)
Line Input as #1 or something like that I cant remember at all |
