Most annoying problem with dreamweaver and SQL database
Currently Active Users: 1193
Discussions: 200,929, Posts: 2,379,148, Members: 246,296
Old August 10th, 2005, 12:49 PM   Digg it!   #1 (permalink)
Come across the most annoying problem ever when trying to import SQL databases into dreamweaver.
First installed apache 2, then PHP 4.4.0, then mysql 4.1.
Got everything up and running, and tried accessing my database through dreamweaver mx2004, which i could as long as i didn't use a password. Came up with the error:
"1251 client does not support authentication protocol requested by server; consider upgrading MySQL client"
Thought this odd considering i had only just downloaded it, searched the web for answer and found it was quite a common problem, and someone suggested updating my PHP software. So I upgraded to PHP 5.0.4 (i think succesfully, the test.php says im running version 5.0.4 so i guess it worked)
Now when i try and import a database in dreamweaver it says "an unidentified error has occured".
I'm using EMS MySQL manager 3 to manage my SQL databases and they are definatly working and can access them fine.
What is dreamweaver on about? Seen lots of people with the same problem but no solutions that i can find. Please someone help. Thanks
BTW: I'm trying to access it on a localhost, thanks
herronial is offline   Reply With Quote
Old August 12th, 2005, 01:17 PM     #2 (permalink)
Banned
Iturea's Avatar
Try changing the password in MySQLAdmin and then using the new password.
Iturea is offline   Reply With Quote
Old August 13th, 2005, 08:16 AM     #3 (permalink)
finally figured it out, i needed to put some file in the system32 directory
3 Table MS Access Relational Database. Problems with INSERT & UPDATE SQL Commands. jetski4419 Webmastering and Programming 0 June 13th, 2005 05:43 PM
SQL Trigger Problem fufiter9246 General Tech Discussion 2 February 28th, 2005 03:53 PM
SQL Problem (Syntax) Blazer06 Webmastering and Programming 9 November 15th, 2004 08:28 PM
sql database on a network share muno Applications and Operating Systems 1 May 27th, 2004 05:27 PM
A simple SQL database? samwichse Linux and Unix 4 November 19th, 2003 06:31 PM
Is It Just Me? (2868)
Obama the Muslim (14)
Regular Build (3)
Fire in DVD (2)
Have you switched yet? (84)
Optical Audio A-B Switch (1)
Virus Doctor Popup? (1)
