my website looks too low budget, help me
Currently Active Users: 2134
Discussions: 200,948, Posts: 2,379,404, Members: 246,309
Old March 14th, 2002, 04:02 AM   Digg it!   #1 (permalink)
Banned
Chooco's Avatar
seriously my site is too low budget looking, how do you guys get such great looking backgrounds and perfect setups?
look at the background of this site i found as a link on mntsnow's site http://24.116.115.130/ how do you get a background like that?
looking at my webpage you can see that the background of the table of links is white, that was white because the background of the pictures used had a white background. how can i get rid of the layers i don't want and have just the words with an INVISIBLE background?
Chooco is offline   Reply With Quote
Old March 14th, 2002, 04:31 AM     #2 (permalink)
angelcat's Avatar
Chooco,
Could I please have a link to your site, so I may take a look, so I can see what you may do to improve it?
Thanks.
Cats are angels with fur!
(O.o)
Vorpal Bunny
angelcat is offline   Reply With Quote
Old March 14th, 2002, 04:43 AM     #3 (permalink)
ChoaticWhisper's Avatar
Send a message via AIM to ChoaticWhisper
Well the background on that site is just a little square that has like to lines of color and it tiles when you set it to the backgound.
On your site I would remove the table boarder that you have your links to other pages in.
Get something like GIMP or other photo program and do a select by color and try to remove the background color on those images like the very top one, remove the black and the white white on the next one.
ChoaticWhisper is offline   Reply With Quote
Old March 14th, 2002, 02:41 PM     #4 (permalink)
ph34r t3h g04t
Whir's Avatar
Unless a background is subtle, like mntsnow's, it can make your page look worse. Don't jump on the tacky bandwagon. Keep it simple if you make a background image. Personally, I prefer solid colors of an odd hue. Then again, I'm not right in the head most days.
-Whir
http://whir.alsherok.net/
Old March 14th, 2002, 07:00 PM     #5 (permalink)
Banned
Chooco's Avatar
Originally posted by ChoaticWhisper remove the background color on those images[/b]
they never had backgrounds.
i made them in PSP and the ONLY layer is the text.
Old March 14th, 2002, 07:34 PM     #6 (permalink)
Cody's Avatar
Check out OSWD.
They have great designs
http://www.oswd.org
Cody
Cody is offline   Reply With Quote
Old March 14th, 2002, 11:05 PM     #7 (permalink)
Xtreme Ultimate Member
Mntsnow's Avatar
Chooco. Doing the images is pretty easy. You just create them on a transparent matte. and use a little bit of javascript to spice things up and you would be amazed at what you can create with Frontpage and other wysiwyg editors. My Digitalmntsnow site is made with just Frontpage and a little bit of handpecked coding. Except of course the splash homepage which was done in Flash5 by none other than our own Socal (she did it for me as I host a few of her sites on my servers)
-Mntsnow-
Mntsnow is offline   Reply With Quote
Old March 15th, 2002, 12:09 AM     #8 (permalink)
Banned
Chooco's Avatar
jeez do you have like T3 servers that everybody wants because you seem to host a LOT of stuff.... your site, NDC, socal (several)
Old March 16th, 2002, 03:05 PM     #9 (permalink)
Steeler Fan
jman01pa's Avatar
Mntsnow
I love your splash homepage.... Great work Socalgal!
J
jman01pa is offline   Reply With Quote
Old March 16th, 2002, 04:21 PM     #10 (permalink)
Praetorian's Avatar
hehe, he's just got a few cable or dsl lines with dedicated 1mbps up and down. Right Mntsnow?
Praetorian is offline   Reply With Quote
Making Health Care Worse (174)
Is It Just Me? (2937)
The disrespect of Obama by Russian .. (22)
Regular Build (6)
Print spooler problem (15)
Point and Shoot Camera Suggestions. (3)
How to convert MP3's (4)
Graphics Card Upgrade Question (3)
Internet Lost (1)
Asus P4G8X Mobo (6)
Have you switched yet? (86)
sms storage to PC (0)
Regular Build (6)
Open With ..... Win7 (0)
java code for fibonacci (1)
